Coolant system vent tube....thing...
By the upper radiator hose, the smaller black hose connected near the water pump, about an inch to the driver's side of where the upper rad hose connects. Is that the vent tube?
It connects to the radiator...which I'm guessing is right, right?
What year car is that LS1 motor out of? I see that the head casting number is 241 which would be a late '00 or newer casting, and the TB looks to be a '98-'00 style judging by the coolant nipple, yet you mention an '02 LS1 in your sig..... did that motor come from the '02 car? If so I think that TB is from a different car......
Odd thing is, I think the '01/'02 cars have a different nipple for the coolant line. What I see in your picture is a hard line coming off the TB, and making a 90 degree bend pointing straight towards the front of the car. That's the same configuration my '98 and '00 have. But, I also have a spare TB (from an '01/'02 car I beleive) that has a different pipe on it, that does not have a 90 degree bend. Odd. Maybe someone did an exchange for a ported TB at some point and ended up with an older TB on the '02 motor?
And that's odd. Don't make me think about it too much, or I'll get scared that this thing isn't going to start...
Sorry, it's late and I'm tired.
Be careful when hooking the lines to the radiator. It's looks like you don't have a stock radiator, as the fill cap is on the driver's side rather than the passenger side. Make sure the steam vent line hose goes directly into the radiator and not into the overflow tube directly below the radiator cap.
A shop reversed the lines on my car which caused overheating problems for obvious reasons. Why, because the steam had no where to go except to the radiator cap, where it was restricted until the radiator cap opens (which vents overflow into the overflow tank).
In addition, the inlet line from the steam vent was connected to the overflow (wrong), so any expanded coolant above the steam vent inlet was venting off into the overflow tank. So the overflow was getting steam from the steam vent line and expanded water from the radiator.
A very simple mistake but stupid on the installers part. I discovered the mistake when I removed the radiator cap and saw bubbles coming from the steam vent line into the radiator cap overflow hole. Coolant should go out of the hole to the overflow tank rather than having coolant come into it.
If you don't have the steam vent inlet in your radiator (a V6 radiator), then I would have one installed. I wouldn't run the car if the steam is recirculating back to the engine rather than into the radiator.
Just make sure you don't vent it into the overflow tank, like they did on mine.
The nipple for the overflow bottle appears to be on the drivers side just under the radiator cap pointing out towards the fender on xthephilx's setup becuase he is not using a stock LS1 radiator. That is the nipple that should be hooked up to an overflow bottle.
As far as I can tell by the pics, everything looks fine.
