Which High output ignition is prefered?
Thanks.
There are 1000+ HP cars out there with the stock coils... They're fine for nearly any application unless you just want to spend the money...
Plugs and wires are a good idea though...
Rob (Bad30th)
If you really really want to, and you have the money, MSD's coil packs are about the best you can do in terms of upgrading over stock. Some people say they are a miracle and make their car idle smoother, pull harder, and get better fuel econonomy. Some just think they're only good for cosmetic reasons.
The stock LS1's have excellent "high output" ignitions. About the only thing you'll gain with an aftermarket ignition, is a whole in your pocket. Some cars may benefit with an aftermarket ignition, but the LS1 comes with one from the factory.
Thanks guys!!
