Crank Pully Questions.
Old Jan 4, 2006 | 11:26 PM
SacLSWon's Avatar
Default Crank Pully Questions.
I am doing my cam swap right now and when i was removing the dampner I did some damage to it I now need to buy a new one. What experiences have you guys had with aftermarket dampners?
I was looking at the SLP one mainly because of the $$$
Old Jan 5, 2006 | 12:11 AM
SgtB's Avatar
how bad did you damage it?
what aboyt getting another one from a a junk yard?
Old Jan 5, 2006 | 12:14 AM
SacLSWon's Avatar
I put the puller on the wrong spot and broke it good. I have a used stocker sittin here just thought while I was at it I might as well replace it with a better one. How is the stock damper compared to aftermarket ones?
Old Jan 5, 2006 | 12:46 AM
Mike K.'s Avatar
I have had bad luck with the asp pulley, after putting on and removing several times It never was tight enough against the crank and ended up spinning on it, ended up tossing it in the trash . The ATI super dampner is a damn good pulley but less Underdrive.
Old Jan 5, 2006 | 01:58 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Mike K.
I have had bad luck with the asp pulley, after putting on and removing several times It never was tight enough against the crank and ended up spinning on it, ended up tossing it in the trash.
I wonder if it has anything to do with your 700 horses running through it!
ATI's are pricey though, but you know the saying already "you get what you pay for."
Old Jan 5, 2006 | 09:34 AM
SgtB's Avatar
with a cam only set up you will be ok with a stocker
Old Jan 5, 2006 | 08:36 PM
SacLSWon's Avatar
what about with a 125 shot? Because as soon as the allmotor end of things are 100% I am going to start my TNT install.
Old Jan 5, 2006 | 11:10 PM
SgtB's Avatar
yep it will hold...I consider N20 a bolt on
Old Jan 5, 2006 | 11:57 PM
SacLSWon's Avatar
ok great news I really appreciate it. Iam now pondering getting a set of stage 2 patriots. I figure since the car is already torn appart why the hell not?
Old Jan 5, 2006 | 11:59 PM
SgtB's Avatar
hey if you have the money do it now
Old Jan 6, 2006 | 12:04 AM
SacLSWon's Avatar
Ha, Have the money, are you serious? I am sadly already looking at not having the car back together till march, why not do heads and wait another month till its back together. I bet those pesky cobras would be realy tryin hard to keep up with a new set of heads.
Old Jan 6, 2006 | 12:56 AM
WsSickLs6's Avatar
now is the time to max out your credit cards...Get as many as you can and run that **** up...Worked for me of course now i pay 500$ a month on them
Old Jan 6, 2006 | 01:02 AM
SacLSWon's Avatar
NOOOO way buddy, I do everything cash. If I dont have it, I DONT HAVE IT. Ive seen way to many people my age do that and get messed up for years. That dosent mean I havent thought about it a few times though. I do have a summit card. Good thing they dont carry kooks or fast or tnt cause then it would be maxxed out in a heart beat. 0% for 365 days on orders over $1500
Old Jan 6, 2006 | 01:07 AM
farsighted770's Avatar
i was also curious about the underdrive pulleys... are the slp ones any good at all... they are expensive so i should hope that they would be good... input?
Old Jan 6, 2006 | 01:55 AM
Mike K.'s Avatar
I think the key is that if you are gonna put it on and take it off alot get the best kind probably an ATI, if its a one shot deal and your done any kind is probably ok. I never had problems until I had removed my ASP for the 3rd time.
Old Jan 6, 2006 | 07:52 AM
SgtB's Avatar
then do it up and buy some heads
Old Jan 6, 2006 | 12:39 PM
SacLSWon's Avatar
Just received my quote from patriot, 1,395 shipped with head gaskets and new bolts. KILLER PRICES. 62CC chambers, he said with the profile cam I have it should have 10:7.1 comp. RIght where I wanted to be. I am going to pick up a set of bare LS6 heads though. $300 good deal so I took em.
The thing that hurts is that I paid 250 for a srping kit from my tunner to use on my stock heads, bought all of the in car install tools. Joint price was like $500. Now for just 2/3 more I could have done a killer set of heads.
Old Jan 6, 2006 | 02:58 PM
you2slo's Avatar
You'll end up using the spring kit in 25,000 miles when you change them. Preventative maintenance pays dividends.
Old Jan 6, 2006 | 11:19 PM
SacLSWon's Avatar
Ok I did it, Got the patriots
My shop ordered them today. I tell ya what, they rock over there both at patriot and my shop. My shop is selling my stock heads with the spring kit I put on them for $500. They know a guy who is looking to do a budget cam swap who has the cam and wants centerbolt heads with upgraded springs.
Seriously though, Patriots prices ROCK. Im pulling the heads in the morning. Putting the cam in and wrappin it up till my heads come in.
Just to let you guys know why im so excited. Im 19, Ive worked my *** off for this car. Im finally seeing where I wanted to go with a car for the first time out of 3 vehicles. I will post up the dyno numbers when I get it running.
Old Jan 6, 2006 | 11:42 PM
WsSickLs6's Avatar
wish i had bought that 02 SOM WS6 when i was 18...i would have saved myself like 60k and had a 9 second car by now...should have stayed in college too
anyway, have fun
