Transmission cooler install- Pictures
Old Jan 7, 2006 | 06:47 PM
CBX's Avatar
CBX
Default Transmission cooler install- Pictures
Do it once, do it right. I keep hearing of all the leaks and problems people are having with transmission coolers with hoses and barbed fittings. I don't want to worry about it once I do it. The factory cooler lines are hard piped, and permanent, plus they help to dissipate heat, so shouldn't the aftermarket cooler be the same? Here's how I did mine.
I bought some 1/2 mild steel flat stock from Home Depot and bent it up to the width of the a/c condenser coil.
I then placed the metal braces in place on the condenser coil, placed the cooler over them, and marked the mounting holes. I then drilled them out to the diameter of the bolts I was using.
I then cut the heads off the bolts and TIG welded the bolt to the straps I made.
I then mounted the cooler to the condenser coil using lock nuts.
Finally, I bent the 3/8" hard lines (in this case brake lines) flared the ends and installed the new lines.
Add some fluid and that's it. Took me the afternoon and it's done right.
Old Jan 7, 2006 | 06:54 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Damn! Very clean. Good job
Old Jan 7, 2006 | 06:55 PM
taintedmeat's Avatar
Looks great
Old Jan 7, 2006 | 07:10 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Very nice.
However, the factory does use rubber lines/clamps as well on one hard line going out of the cooler and back to the trans. It's a flare end on the hard line going to the rubber hose. That is where I spliced into mine for the aftermaket cooler. Then I put a barbed fitting to splice the other end (bought a better fitting than what came with the kit, made a much tigher fit into the hose) and the cooler already came with flare fittings for its input/outputs. I used 5/16" Goodyear hose (Goodyear is a lot thicker on the outside than other brands of 5/16" trans hose is, allowing greater clamping force without bottoming out the clamp) and fuel injection clamps to hold all the lines together. Bascially I scrapped all the worm gear clamps and the crap 11/32" hose that came with the B&M kit and used better hardware.
Never had any leaks doing it that way, ever. On the other hand, I used to have leaking issues when I used the 11/32" hose over the factory hard line (too big) or the worm gear clamps. I think those two items are what cause most people to devlope leaks.
Old Jan 7, 2006 | 07:14 PM
CBX's Avatar
CBX
Originally Posted by RPM WS6
Very nice.
Thats what I was trying to avoid. I wanted it hard piped only. One less thing to worry about.
Old Jan 7, 2006 | 07:26 PM
Ωmega's Avatar
Very nice. Looks good and clean
Old Jan 7, 2006 | 07:36 PM
Danny2tek's Avatar
very nice
Old Jan 7, 2006 | 08:59 PM
bitchncamaro's Avatar
looks damm good ...Doing mine next weekend,Thanks for the pics...
Old Jan 7, 2006 | 09:11 PM
SLPSS01's Avatar
very nice.
Old Jan 8, 2006 | 12:58 AM
REDWS6ROCKET's Avatar
man you make me feel like i duct taped mine on.
Old Jan 8, 2006 | 05:36 PM
Slacker's Avatar
That is one clean install, good job.
