Need Your Input/Help Valvecovers *PIC'S*
Currently they look like this.....
What shold i use to fill the holes??
Ive had others say get someone to Tig weld it closed.... but ive also heard of them splotting and ruining the valve covers....
Should i just leave the holes and just polish them out??
Or go with a set like this from Na$ty Performance
Im going to at least finish these up and see what they look like before i go with a different set........
I think both will look good on this......... when finished
What do you guys think??
Thanks
Kyle
however id suggest the ones from nasty or have the holes filled.
No doubt, go with the welded ones. Take a look at Tony's red '69 for what they look like chromed.
but the aftermarket ones will always look meaner and better due to their size alone....lookin good though.
Here again......... Size does Matter......
WILWAXU..... its both
Move it if ya like......
You don't even have to weld (you should, but dont have to) polish the covers, fill with epoxy and paint the epoxied holes black. Consider it "character."
** How about this: You have the rest of the motor satin colored. Why just have one or two items polished? Why not paint the valve covers, water pump(minus pulley), and the other misc parts to "tie it together" the same metallic green?
You can fill the holes with epoxy which will be covered completely by the color!
Im going to work on the stockers some tonight.....
If i do decide to do the Taller Fabbed ones i will sell the stockers.
Kyle
Get the after market covers...it is obvious you spared no expense to this point. Why quit now?
Big hairdryer = Big Valve covers
Although I do like the idea of painting them Green
Just recieved this pic yesterday evening.... gunna post it for a over all look....there black now.... and then the set im working on polishing up..... or the Tall ones from Na$ty Performance......
Thanks for your input guys.
Kyle
Nate makes nice stuff. I have his race tank and fuel system. Highly reconmend his products.
I say keep the holes and have the most intricate PCV system in history!
Have someone Tig them up who has a good hand, then smooth them out to a brushed or polished finish. Fill the long lines with some metallic green, THAT would be flippin sweet.
I use a wirewheel in my die trinder on alot of aluminum stuff (valve cover, throttle body, MAF ends) It's very easy to do and provides pretty nice looks. Its a small wire wheel, only meant to be used in drill motors and not over 2500 rpms, i figured its good to about 15k, thats when the wires start flying out lol. Check out how bling my throttle body is in the top pic on this thread, i did that with a wire wheel.
https://ls1tech.com/forums/generation-iii-external-engine/428410-pics-greddy-catch-can-install-56k.html
