My Custom True Duals OTA (pics inside)
Just thought I'd share some pics and info on my true duals so you guys can get some ideas. Setup includes Pacesetter long tube headers, 2.5" true duals to X pipe over the axle and glass packs with SLP loud mouth tips. I had these custom made by a shop here in Cincy (SN on here is SRP) out of mandrel pre-bent tubing from summit and some old glass packs. This is in no way an add for the shop so mods please don't delete.
Since the pics were taken everything has been coated, I've added cut-outs after the X to get it a bit louder when I want, and put the stock upper PHB back in since the BMR piece wasn't needed. Any questions feel free to ask. Enjoy the pics and vids.
Cut-outs closed, pass by and idle
http://nkyfba.homeip.net/nkyfba/atta...achmentid=3898
Cut-outs open, burn out
http://nkyfba.homeip.net/nkyfba/atta...achmentid=4144
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://pic11.picturetrail.com/VOL367/977291/5042510/105441698.jpg)
![](http://pic11.picturetrail.com/VOL367/977291/5042510/105441716.jpg)
![](http://pic11.picturetrail.com/VOL367/977291/5042510/105441731.jpg)
![](http://pic11.picturetrail.com/VOL367/977291/5042510/105441811.jpg)
![](http://pic11.picturetrail.com/VOL367/977291/5042510/105441830.jpg)
Originally Posted by weestro
How are your clearances? That last pic looks like it hangs kind of low.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
!LS1 11 Second Club
It's pretty stealthy at idle. In the first vid, you snuck up on the camera towards the end. Hehehe.
TD's out the back kick ***.
Sounds Nice! I agree on the welds though- they look a little grizzly.
There's no problem with the exhaust running into each other at the X pipe? Wouldn't it be better if they went all the way back in their own pipes? Its not really dual exhaust is it????
Just wondering if that matters flow-wise.
Nice looking job though, I'd like to get that done on mine either way.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
!LS1 11 Second Club
Yes indeed, X is the way to go for Scavenging. Look under a NASCAR vehicle and you'll see one there.
Even a well made Y-merge will scavenge well.
Straight pipes sound like *** on our cars.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
How much did that set-up cost you total? Im still planning my entire setup for when I get my T/A. Ive been stuck on GMMG a while. It would be between that and true duals. I like the sound of TDs but am worried that it will be too loud to daily drive. I ve listened to them on ls1sounds and theyre nice, but its alot different in person I assume. I havent found anyone in my area with TDs to listen to. Hows interior drone, raspiness, etc.?
Originally Posted by Allergik2dyin
How much did that setup cost you total? Im still planning my entire setup for when I get my T/A. Ive been stuck on GMMG a while. It would be between that and true duals. I like the sound of TDs but am worried that it will be too loud to daily drive. I ve listened to them on ls1sounds and theyre nice, but its alot different in person I assume. I havent found anyone in my area with TDs to listen to. Hows interior drone, raspiness, etc.?
As far as sound, My previous set up was Mac mids/ Ypipe and a loud mouth which was fun at times but quite unbearable most of the time. You'll understand when I tell you that this is pretty quiet compared to before. No interior noise (accept when the cut-outs are open which still isn't bad) and the rasp from before is gone. The best part about it is that I don't have to tip toe around the local police in 5th and 6th gear like I used to.
Originally Posted by v8hunter
I think that it looks well put together and really doesn't hang down badly...only one thing missing...I want to see how it looks from the back of the car.
![](http://pic11.picturetrail.com/VOL367/977291/5042510/125485735.jpg)
closer under the back
![](http://pic11.picturetrail.com/VOL367/977291/5042510/125485738.jpg)
from the under the passenger side
![](http://pic11.picturetrail.com/VOL367/977291/5042510/125485742.jpg)
Is the "X" pipe better than using this: I was gonna use the 3" inlet, 4" outlet type.
http://www.thunderracing.com/catalog...id=438&pcid=54
You mention the cutouts but I didn't see them in the first shots. Did you add them later. I see a hint of them in the second post/set of pics. Can you get a close up of them?
How are they right after the X? Feel you lose any low end like when they are right after the headers?
Originally Posted by Full-Force
Hey Wino, can you loan me some of that money you got?
Dude, you just destroyed a set of tires with that burnout. Car was hopping like a ****, I ssume from changing gears.
good stuff
Those tires were a 2 yr. old set of BFG DRs that needed finished off I had to show some people up anyway. And yes, that was 1-2-3-4 gears.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Originally Posted by Ric
THANK YOU.
I've been hoping to hear an LS1 on dual glasspacks for sometime, now. I'll definitely be doing the same setup with ours.
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
Well, it won't really be a 3" system. I just remember seeing a thread that compared 2.5" mufflers across the board, and glasspacks & chambered mufflers didn't fair well at all. Thus, my reasoning behind going 3" glasspacks. I'll be hacking a couple of OEM catbacks to make my own 2.75" duals with an H-pipe that has a fatter equalizer than just a pipe... I imagine it to perform between an H and an X.
