View Poll Results: Which Muffler on a TSP TD X-Pipe?
Dynomax Bullets
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
55
31.98%
Moroso Spiral Flows
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
38
22.09%
Sweet Thunder
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
79
45.93%
Voters: 172. You may not vote on this poll
Sweet Thunder vs Moroso Spiral vs Dynomax
#81
That's what she said...
Originally Posted by speed_demon24
And dont forget with the spiral flows, it goes into a 4" case where the spirals are, it doesn't just stay a 3" case, thats about a 40% increase in area right there, so spiral flows probably flow as good as a bullet.
#82
Originally Posted by TheBlurLS1
Bullets do the same thing, accept there is nothing inside. You can stick a 3" pipe all the way through them without hitting anything.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#83
Bullets stay 3" inside where part from 3-4" is packed with insulation, the spiral flows expand out to the outter 4" case on the inside. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
#84
But the inside of the bullet will flow just as well as the pipe leading up to, and leaving it, so how are you going to improve upon that? ![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
