Which Motor Mounts???
Old Jan 21, 2006 | 12:10 AM
BLACKOUTZ28's Avatar
Thanks for hijacking my thread guys....nah jk its cool
So which motor mounts do you guys think would work the best?
Spohn LS1 Solid Motor Mounts
OR
Prothan Poly Motor Mounts
Old Jan 21, 2006 | 01:15 AM
TheBlurLS1's Avatar
That's what she said...
Prothane, the solids scare me. I dont have the ***** that SUX2BU has
The solids i can imagine are going to cause more vibrations that you will care to have. They are mostly used to drop some poundage i think. The prothane will work perfect, plus give you a bit of flex. I like to know that if i need to drop my trans, i can unbolt the tranny mount, and tilt the trans down to remove the top bolts from the bellhousing. Try this with sold motor mounts.......
Sux2bu's whole car only actually weighs about 12lbs at this point.
Old Jan 21, 2006 | 09:17 AM
NHRATA01's Avatar
OR
Well now ya got a thread to go back to reference when you do the install Since the search is dead.
I went with the Prothane mounts myself. I don't think you need solids unless your hardcore, and the car is more of a track car than a street car. Just MHO.
Old Jan 21, 2006 | 03:29 PM
DVSWS6's Avatar
Sorry for the hijack! <---me Back to the original question in this thread, I would just go poly unless you are hardcore racing it. With both poly mounts my engine barely torques over with a real good punch of the throttle. It's like solid without being solid, ya know?
Old Jan 21, 2006 | 06:19 PM
SUX2BU's Avatar
He is right. i have to loosen the rear four bolts on my K member to drop my tranny.
Old Jan 21, 2006 | 06:42 PM
BlackHawk T/A's Avatar
That's awesome, because I just did Prothane Poly mounts with my header install, and the transmission is coming out next
Old Jan 21, 2006 | 06:53 PM
SS1875's Avatar
Hey guys Im planing on changing the motor mounts but which ones do you think would be best to get?
OR
I would really appreciate your help.
Steve
Im running the Prothane mounts currently...very solid feeling without being a SOLID mount. One of the best moves I've made!!
Old Jan 22, 2006 | 02:26 AM
Thanks for all the input guys...I guess I'll just go with prothan mounts...cus the tranny will have to be dropped to put the converter in…when I get one.
Steve
