90mm tb to 85mm maf
Old Jan 20, 2006 | 05:38 PM
BBBBadSS's Avatar
Default 90mm tb to 85mm maf
what are you guys using to connect your 90mm tb's to 85mm maf. will the slp bellow work or is there something better that looks clean? thank you for any info.
Old Jan 20, 2006 | 09:06 PM
WILWAXU's Avatar
I've been told/read that the SLP will work.
Old Jan 21, 2006 | 12:09 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Anything that transitions from 3.5" to 4" works. Trim/cut/notch to fit.
Old Jan 21, 2006 | 10:50 AM
Quickin's Avatar
Not that its gonna make a real big difference, but wouldn't a 90mm MAF be the way to go? Wouldn't an 85mm MAF be the weak link in an 90mm TB and Intake set-up. And again, I know it won't be much of a loss anyway.
Does anyone even make a 90mm MAF?
Old Jan 21, 2006 | 10:56 AM
!LS1 11 Second Club
^ Find us a 90mm MAF
If I would have known of a readily available one, I'da bought it.
Old Jan 21, 2006 | 11:21 AM
MadBill's Avatar
I'd say if someone really wanted a 90 mm MAF, they would cut the guts out of a standard one and graft them into a 90 mm tube. A little magic with the appropriate tables and off you go. So simple, at least to describe...
Old Jan 21, 2006 | 12:54 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that would be the fastest way to jack one up as well.
Old Jan 21, 2006 | 02:36 PM
BBBBadSS's Avatar
Does anyone make a 85mm clear lid, or just black? Who makes the best 85mm lid, or are they pretty much equal?
Old Jan 21, 2006 | 04:51 PM
NHRATA01's Avatar
AFAIK, TSP makes the only 85mm lid. I think i'm going to buy one soon, since I have an 85mm MAF and just bought a FAST 90 setup.
Old Jan 21, 2006 | 10:14 PM
LawmanSS's Avatar
I used the SLP bellows to connect an SLP 85mm MAF to a Nick Williams 90mm TB...
Old Jan 22, 2006 | 06:18 AM
TAQuickness's Avatar
I gues nobody has ever taken a micrometer to the ID's of your 75mm lids vs 85mm MAF's
Old Jan 22, 2006 | 05:50 PM
sickss228's Avatar
Is there that much of a difference, any power gain you think?
Old Jan 22, 2006 | 06:34 PM
Quickin's Avatar
I guess you could just ditch the MAF and do a SD tune.
Old Jan 22, 2006 | 06:35 PM
Quickin's Avatar
I don't know why a company doesn't make them, they'd sell thousands of them. And while their at it make a 95 or 100 too, things are only going to get better and they will be needed in a year or two.
Old Jan 22, 2006 | 07:08 PM
bmfcamaro's Avatar
dont buy a 85 from tsp. they are thin pos'. fast toys is coming out with a 90 hopefully soon. most likely done way better than the tsp piece.
Old Jan 22, 2006 | 07:29 PM
!LS1 11 Second Club
Mine worked wonderfully.
Old Jan 22, 2006 | 08:31 PM
SS1875's Avatar
I'm running the K&N FIPK kit and my Delphi 85mm MAF and FAST 90mm hooked right up with no issues...lucky I guess.
