Peterock/Qtp header install
Old Jan 21, 2006 | 08:29 AM
peterock98's Avatar
Default Peterock/Qtp header install
I'am installing new headers today on my back.I printed out the slp directions from ls1camaro.net.Does any one else have any other suggestions before I start.
Old Jan 21, 2006 | 09:42 AM
taintedmeat's Avatar
Have all the tools laying on the ground in arm's reach. I've always hated to roll out from under the car, get up, and go dig through the toolbox for something I should have known I'd need before I started.
Old Jan 21, 2006 | 09:56 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
If you're using SLP instrucions, remember that QTP's slide right in, you don't have to undo the tranny at the cross member. Just point the QTP's straight up and down (collector facing the floor), and you're fine.
Old Jan 21, 2006 | 10:41 AM
Zymosis's Avatar
for the qtps - get the car as high as you safely can (i had 2 about 8 inches of wood ontop of my jack)
I had to remove the oil filter to get the drivers side in, i thought if I could get it high enough it would just slide in, it would not. So I took the oil filter off, and slid right in.
Passanger side had to remove coil pack to get to back bolt easier. I'm sure it isnt required, but sure helped. Also removed dipstick on that side.
the next best advice I can offer, is have a friend there, nothing like another set of hands to help get stuff done
Old Jan 21, 2006 | 02:00 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
All long tubes you want to have it up as high as you can without it being too much of a safety issue.
Old Jan 21, 2006 | 06:02 PM
peterock98's Avatar
Ok I worked 5 hours and now I have some problems.All the old stuff is off and the passenger side on.I could not get the the drives side.It's hitting the bell housing and the k member.
Old Jan 21, 2006 | 06:06 PM
peterock98's Avatar
Do I need to take off the motor mount and lift up drivers side.Also What's the best way to do it..
Old Jan 21, 2006 | 06:11 PM
Lithium's Avatar
SSU's Drunk Typing Whore
https://ls1tech.com/forums/showthread.php?t=139142
Old Jan 21, 2006 | 06:22 PM
peterock98's Avatar
I read that I guess I did not the the car high enough in the air.
Old Jan 21, 2006 | 06:46 PM
LS1LUNATIC's Avatar
I had the car on a lift and when trying to get the drivers side in it wouldnt go. So I had to undo the drivers side motor mount and put a jack up under it and lift it up a couple of inches. After that slid right in. Passenger side was a breeze, no hassle what so ever. Just be sure not to damage any sparkplugs while pulling manifolds and putting lt's back in.
Old Jan 21, 2006 | 06:59 PM
peterock98's Avatar
This my first header install how do I remove the motormount?Also did you have to take of the steering linkage.
Old Jan 21, 2006 | 07:25 PM
slow trap's Avatar
i had to take off the steering linkage and cut it apart and put a smaller diameter piece inside it and weld it because it was rubbing,BAD! i also took off the oil filter,and the motor mount and still had to take the perch off also.i hope you have better luck than i did.oh yeah i had to heat and bend-dimple both sides to keep from hitting where my a-arms bolt up.my flowtechs fell out on both sides !
Old Jan 22, 2006 | 08:05 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
you would put something like this up for him!
Old Jan 22, 2006 | 03:29 PM
Firehawk441's Avatar
I'm not exactly sure why you are having so much trouble since I'm not there to see it, but I have now installed 7 sets of these headers and 2 sets of 1 7/8 headers. If you remove the steering shaft, oil filter, and drain plug, they should go right in provided you have the car high enough. With the collector directly facing the ground, you should be able to push the header into place. There is definatly no reason to undo your motor mounts. If you still have trouble, I suggest you contact QTP and talk to Barry about this.
Old Jan 22, 2006 | 05:13 PM
SSJIMMY's Avatar
I hope mine go on easy when i get them in a month or so but I hope to have access to a lift so that will help.
Old Jan 22, 2006 | 06:45 PM
peterock98's Avatar
I got it on.I broke the *uck'in peice I think it's the fuel regulator it's on the drivers side there are two rubber lines.I snapped it's alittle plastic peace it by leaning on...does any how much this part cost.
Old Jan 22, 2006 | 06:48 PM
peterock98's Avatar
There is a pic Where the thread starts .My F/T Header install - Broken041 (Kim)
That is the part.
Old Jan 22, 2006 | 08:11 PM
peterock98's Avatar
Ttp does anyone what part that is.
Old Jan 23, 2006 | 10:07 AM
slow trap's Avatar
are you talking about the thing with the greenish cap on it? if so i can't remember exactly but i think it's called a maintenance port or some kind of port.maybe someone will know.
