Advice on Cutout location
Old Jan 23, 2006 | 12:52 AM
98Trans's Avatar
Default Advice on Cutout location
Hey guys, I was just curious I'm looking at getting the TSP Rumbler with a Sweet Thunder in the I pipe. My question is where should I place a cutout??? I mean, if you have a muffler in the rear end of the car and you place a cutout before the muffler, I can see how a cutout would make it louder in that situation. But, with a Sweet Thunder or any bullet type muffler in the I pipe section, where would you place the cutout to achieve maximum performance/LOUDNESS? haha, thanks guys!
Old Jan 23, 2006 | 01:10 AM
frisky2101's Avatar
you could do a dual cutout setup just aft of the headers, be careful of clearance issues
Old Jan 23, 2006 | 01:35 AM
98Trans's Avatar
Well, thats the problem...I'm going to be running stock manifolds/cats. So I'm wondering where I should put it.
Old Jan 23, 2006 | 01:41 AM
frisky2101's Avatar
I see, In my opinion I would not put a cutout on stock manifolds, but that is just me
not exactly sure how that would sound.... My advise is save and buy headers first, hen worry about the cutout
Old Jan 23, 2006 | 01:50 AM
Redneck Z's Avatar
With stock manifolds and the TSP rumbler you probably won't make any power with a cutout. It will just be louder and more raspy. I wouldn't use one if I was you.
Old Jan 23, 2006 | 03:33 AM
300bhp/ton's Avatar
With a good cat back the best place to put a cut out is on the shelf (IMO ).
A good catback will remove all the restriction from the muffler and the tubing on at least a FULL bolt on car and even a cam/bolt on car. This means that having a cutout will offer either nothing or vry little in the way of improved flow rate, which means little or no gain in HP. There should be a gain in noise (which is some people's prime aim), but that'll be about it.
Currently your restriction lies in the headers/CATS/mid pipe and it is not feasible to use a cutout to by pass all of them.
As for actually using cutouts, well you usually have 2 options:
1. single cutout
2. dual cutouts
If you have dual cutout's then placing them between the engine and CATS will allow you to bypass them (improved flow = more HP), however it also bypasses the merge collector on the Y pipe so you will miss out on any scavenging. This may have a greater drop in HP over that gained by by-passing the CATS.
IMO - Unless you are fitting the cutout 100% for noise purposes I would advise using the money to save up and get some other mod such as long tube headers.
Old Jan 23, 2006 | 06:00 PM
98Trans's Avatar
Damn, I keep running into problems with exhaust! The problem is I need to keep my cats and manifold for CA smog laws. So, I basically need a LOUD cat-back. GMMG is just too pricey and not loud enough in my opinion. The LM I'm worried about being too raspy and backfiring. The TSP Rumbler is cheap and no rasp.....but again, worried about it not being loud enough. The only reason for the cutout would be to make it LOUD.
Thanks for all the input guys! What you guys suggest? I've heard about the Bassani duals for stock manifolds/cats....but from what I heard of it, I dont care for it at all. How can I make this thing scream (in a good way) with cats and a manifold???
Old Jan 23, 2006 | 06:07 PM
Order 66's Avatar
1. single cutout
2. dual cutouts
Any proof to your statment, because i have seen many many times a cutout will make more power than catbacks. It has been proven. Why do you think they are so popular. Now on some catbacks the gains might not be tremendous but still gain a couple of hp. The problem is you cant get a high flowing catback with out the noise. That is why i like my cutout. Loud when i want and quiet when i want.
Any to answer the orginal question you can place the cutout before the resonator on the rumble. I might be tight but i have not seen a rumbler first hand.
Old Jan 23, 2006 | 07:25 PM
98Trans's Avatar
Has anyone ran a setup like this before??? Cutout on a catback with stock cats/manifold??? ...I wonder how it would sound
Old Jan 24, 2006 | 04:52 AM
300bhp/ton's Avatar
Only what I have read on this site, and a rudimentary understanding of physics. Basically it's a lot of info, if you want to know read the STICKY (Mod Guide) in this forum, post 13 onwards, which is written by David Vizard (a respected engineer in the motoring world). It explains exhaust flow and exhaust pressure wave.
In simple terms if your exhuast flow sufficently for the BHP being produced then a decrease in restriction will yield no power gain. You may affect the exhasut pressure wave which can produce more power, but then again a cutout may have a nagative affect on it also.
So yes there is lots and lots of proof and evidence, but it's taken me 6 months of researching and reading, however if you have a spare 30mins to an hour I'm sure you can find some useful info.
As for cutouts themself, yes they are a geat idea if you plan on keeping a stock exhaust or want to run a quiet setup but still want the ability to be noisy at times. But for me the setup I'm fitting to my car will be loud enough for my liking, and the only restriction will be the actually tubing itself, which a cutout will not be able to by-pass. The muffler will be flowing as well as the rest of the exhaust so it won't be the restriction.
Old Jan 24, 2006 | 04:54 AM
300bhp/ton's Avatar
Probably not that much different, as the muffler used in the Rumbler is a straight thru design and doesn't really reduce the volume of the exhaust anyhow. The cutout would make a less toned sound and of course it would eminate from under the car so would sound louder inside.
Old Jan 24, 2006 | 05:05 AM
300bhp/ton's Avatar
Exhaust are a large area. And I've spent too much time researching them. Duals I have to say do sound best and on high BHP cars can often outperform Y pipe setups BUT not always. All in all there are still drawbacks with dual setup so after much deliberation I'm going Y pipe setup.
I know if you're in CA it's a pain. But there are still options out there just depends on how lucky you feel. A set of Long Tube headers with a CATTED Y pipe will keep you emissions friendly (although the location of the CATS will still be illegal).
Mac Mids maybe another option with a Catted Y pipe. You'll want to keep all the emisisons stuff such as EGR and AIR as they don't cost any HP and will keep you legal.
Then for loud exhaust yes GMMG is good and 2nd hand isn't too expensive. The Rumbler is a good price but it's only mild steel I beleive (not really an issue in CA I guess). But personally I'm gonna go for the Loudmouth. With CATS it shouldn't be too raspy and it will be loud. If I find it's not quit the sound I'm after I'm going to turn it into a Magnamouth using muffler PART # 14619 $150
http://www.magnaflow.com/02product/s...ne=main&id=660
As this is only a 3" catback it will be slightly restrctive on a bolt on/cam car if it's anywhere near 400rwhp. But from what I've seen I would guess at only 8-12rwhp over a 2.5" dual setup (but I can live with that).
Have you tried www.ls1sounds.com yet? Personally I like the sound of the LM clips on there, and only a couple of them sound raspy to me.
Old Jan 24, 2006 | 10:21 PM
98Trans's Avatar
Hey, thanks for the posts guys! I have tried ls1sounds.com, it has its pros and cons. I was going to go LM just to be LOUD.....but with all the negative comments, I was afraid of spending $400 for a raspy exhaust. Especially when you can get the Rumbler for $200 and no rasp. But, its not very loud at all with the Dynomax bullet. So, I was planning on a Sweet Thunder in the I pipe...but I've heard it makes a weird suction-like sound. So I'm thinking maybe a Stainless Works Chambered muffler might be better. ....Then again, I'd be worried about being loud. So I guess I'll keep giving it some thought. I have heard great things about the MAGNAMOUTH. Have you heard it before??? I wonder if its more quiet with the Magnaflow, or just as loud....but refined. Thats what I'd hope for.
