View Poll Results: PCV Options
Leave it alone.
15
11.11%
Add a catch can.
47
34.81%
Change to a truck PCV valve.
9
6.67%
Remove the entire system and run a breather.
64
47.41%
Voters: 135. You may not vote on this poll
What to do with PCV system?
Old Jan 24, 2006 | 01:45 PM
FL01SS's Avatar
Default What to do with PCV system?
Help me decide what to do with the PCV system. Let me know the results of what you've done and what you think is best.
Old Jan 24, 2006 | 03:34 PM
BLUE99T/A's Avatar
I tried everything to get rid of oil consumption. (catch can, 01-02 style valley/pcv , the new truck pcv valve) I still find oil behind my tb and have to add a quart every 1500 miles. My suggestion would be to learn to live with it. I have.
Old Jan 25, 2006 | 02:46 AM
SUX2BU's Avatar
Only way to get NO oil in your intake is to ditch the PCV and run breathers. thats what i do.
Old Jan 25, 2006 | 09:01 AM
LS69TA's Avatar
I've got the truck pcv valve and a catchcan and it still uses oil. I may switch to breathers before too long.
Old Jan 25, 2006 | 10:24 AM
LS1-450's Avatar
If a 2001 is similar to a 99 PVC set up, then a larger diameter drain hole inside the passenger side valve cover in conjunction with a vertically mounted PCV valve & a just in case fuel filter, will eliminate oil consumption. Let me know if this is of interest & I will explain further. AM not sure how a 2001 PCV system i routed. If it's the same, this will work.
Old Jan 25, 2006 | 10:27 AM
Matt D's Avatar
Retired Street Racer
Some people will have oil and some don't. Like you said, just deal with it, it isn't hurting anything.
Old Jan 25, 2006 | 10:30 AM
~JOSHUA's Avatar
Default Mine's deleted. Looks better without the clutter.
Old Jan 25, 2006 | 10:55 AM
KILLERARMY's Avatar
Thunder racing has a LS6 PCV Conversion Kit to comeback oil consumption for LS1 cars.
Old Jan 25, 2006 | 12:03 PM
SUX2BU's Avatar
https://ls1tech.com/forums/showpost....40&postcount=7
Old Jan 25, 2006 | 12:07 PM
LS1-450's Avatar
Originally Posted by FIREHAWK#608
Breather
How did you attatch the breather; 1/8" NPT nipple in the oil cap or a different way? Thanks.
Old Jan 25, 2006 | 12:19 PM
~JOSHUA's Avatar
Mine screws right into the stock oil "chimney." You can find them at Year One(sponsor) ===>
$50something dollars.
Old Jan 25, 2006 | 01:49 PM
LS1-450's Avatar
Are you saying that the back pressure created by the PCV circuit was enough to blow the seals on the second motor you had or that the overflowing catch can caused the back pressure & subsequent seal failure? Where did you mount the driver's side head cover breather?
Old Jan 25, 2006 | 05:44 PM
BackinBlack02SS's Avatar
What did you do about the driver's side?
Old Jan 25, 2006 | 05:58 PM
SUX2BU's Avatar
What i'm sayin is that the second motor had ALOT more blowby than the first (it also ran faster ) and the stock PCV system with a catch can did not flow enuff and so it came out of the seals.
As for the driverside head you can use the same filler cap breathwer ($50 a piece ) if you have 98 heads. for 99 and up heads you can just use a passenger valve cover on the driverside.
i thought it was retarded to spend $100 on two breathers so i bought clamp on breathers fron jegs for $12 a peice and welded a 1 3/8" tube on each valve cover.
Old Jan 26, 2006 | 07:40 AM
~JOSHUA's Avatar
Think about the internals of the engine. The holes where the pushrods go through to touch the cam is a common area. Any pressure on the other side (drivers) migrates to the lower pressure side where it naturally goes to the breather.
Simple.
Old Jan 26, 2006 | 07:53 AM
Simple.
This is true, however when gasses are being pushed out, air must also be sucked in.
Old Jan 26, 2006 | 10:16 AM
~JOSHUA's Avatar
Yep, through the breather. No problem
Old Jan 26, 2006 | 10:32 AM
So 1 single breather on the passenger side is all that is needed?
Old Jan 26, 2006 | 10:39 AM
~JOSHUA's Avatar
Yep, look at any NASCAR or 1st gen racing small-block. No worries.
Old Jan 26, 2006 | 05:31 PM
ls2 bait's Avatar
why not just use the gm vented cap?
