SLP Exhaust Questions!
Im getting the slp loudmouth, but i also wanna get the larger Y-Pipe. Does anyone know if this bolts to the stock mainfolds? Also will this eliminate the need for cats. So it would go, manifolds, y-pipe, then the slp loudmouth.
Next question is this. What if i purchase the package with the headers and the y-pipe. Then do i need cats as it says slp's website? and where do these bolt on?
I need to know which y-pipe to get cause im gunna have to get cats to pass emissions. Any good high flowing cats?? or do i hollow out the stocks. Also will the slp exhaust mount right up to any y-pipe that i purchase.
Have you ever heard the loudmouth with headers. Many people on here say it sounds bad; mostly because of rasp and interior drone. I didn't listen to them and tried it anyways. I didn't like it either. I changed mufflers after about two weeks. Some people like it though.
I don't know who all sells catted y-pipes. I knew from the start that I didn't want them. Some of the high-flow cats don't pass emissions in some states anyways.
What setup should i get for an agressive muscle car tone.
Im not purchasing the headers until later. but for now im planning on the slp y-pipe then which catback should i get.. everyone talks about this rasp!! if you have headers, then y-pipe, then a loudmouth!
I would probably choose the exhaust first, then get the Y-Pipe that goes with it, for stock exhaust or headers. When I got my SLP long tubes, they came with the a new Y. I would not recommend the SLP headers, even though I got great power and sound out of them, because they hang so low, and are the hardest to install. I do heartily recommend the LoudMouth exhaust, though. You can always get the Loudmouth II, which lets you swap in a muffler if you want.
