catch cans? question real easy
Old Feb 7, 2006 | 12:20 PM
rgaynor85's Avatar
Default catch cans? question real easy
ok im gonna try to catch can approch to oil consumption and see how it works out, now do i run 2 catch can one for the pcv valve line and 1 in the beather line that goes into the TB or just on the pcv line, i wasnt sure if the TB line sucked or pushed air from the TB oh and another thing do u guys keep the pcv valve in there when u use a catch can or take it out, is it really needed when u have the can
Old Feb 7, 2006 | 12:50 PM
v8hunter's Avatar
I only used 1 like most people. Mine is between the pvc valve and the intake. I used the cheapo approach using an air compressor filter and it works great, but needs to be emptied regularly.
Old Feb 7, 2006 | 01:00 PM
rgaynor85's Avatar
yeah thats what im prolly gonna do but on the air compressor filters they say not to use with synthetic oil
Old Feb 7, 2006 | 02:16 PM
weestro's Avatar
You only need 1 inbetween the mani neck and the PCV valve. That connection sucks in air (and oil) from the valve covers.
Old Feb 7, 2006 | 02:27 PM
rgaynor85's Avatar
thats doesnt sounds right the pcv valve line goes into the intake mani the tb is just a straight line to the valve cover
Old Feb 7, 2006 | 02:30 PM
LS69TA's Avatar
That's what I did. It catches a good bit of oil. I have to empty it almost once a week. It's about 1/4 full when I dump it out.
Old Feb 7, 2006 | 02:32 PM
rgaynor85's Avatar
hmm that much huh damn i gonna get a sears one tonite those r nice ones, everyone used to use them on my old tubo mazda mazda i had
Old Feb 7, 2006 | 02:41 PM
weestro's Avatar
Sorry, you're right, I meant mani neck.
Here's my setup:
Old Feb 7, 2006 | 03:11 PM
rgaynor85's Avatar
so how much oil do u catch in that big thing, i know the compressor filters work cause ive used them on other cars but i wonder about those big things if they work better or worse
Old Feb 7, 2006 | 03:22 PM
weestro's Avatar
Actually at the same time I installed it I switched to 5W40 and it's still empty. There is a teeny bit starting to creep into the line just passed the PCV tho. I think the function is all the same, it's just a matter of capacity. The AWM can ($160) has a chamber inside with some steel wool material to catch absolutely everything but hey...too much for a can.
Old Feb 7, 2006 | 03:42 PM
rgaynor85's Avatar
well what exactly is those big greddy type catch cans u get on ebay, are they the same material inside as the compressor filters.
Old Feb 7, 2006 | 05:59 PM
YO-EL's Avatar
Here's my AMW I just installed on my 2000 LS1 Corvette..
Tubing goes from PCV valve to TOP of the can, then
run tubing from SIDE of can INTO INTAKE...
Very simple!
Old Feb 7, 2006 | 06:10 PM
NC98Z's Avatar
Thanks dude 1 picture is worth a thousand posts around here.
