Quick intake question
Old Feb 11, 2006 | 11:31 AM
Jstyle's Avatar
Default Quick intake question
a few quick questions will the ls2 intake manifold fit on the my 00 c5? If so what part numbers do I have to get with it. Will my stock throttle body work with it? Also what manifold came on the 05 CTS-V? Thanks every one...
Old Feb 11, 2006 | 12:25 PM
HeapaShifter's Avatar
The LS2 intake will fit on a 00 C5, but a LS6 intake flows better so I'd recommend that instead.
The stock C5 throttle body won't fit a LS2 intake. The LS1 intake mounts with 3 bolts and the LS2 mounts with 4 bolts. The LS2 throttle body is 90mm verses the LS1's 78mm. Then there's also a problem with the electronic throttle.
The 05 CTS-V has a LS6 engine which comes with the LS6 intake.
Old Feb 11, 2006 | 10:39 PM
Jstyle's Avatar
thanks for the advice on all of that the ls6 looks like the way to go then...
Old Mar 9, 2006 | 07:08 PM
GIGAPUNK's Avatar
Going the other way around:
Will a '03 vette computer control the 90mm LS2 ETC properly?
I guess if an LS2 computer will control a LS6 TB then it would make sense that it should work the other way around right?
Old Mar 9, 2006 | 11:02 PM
WILWAXU's Avatar
Some reading on using the vette throttle bodies:
https://ls1tech.com/forums/generation-iv-internal-engine/216495-ls2-tb-s-sdpc.html
https://ls1tech.com/forums/generation-iv-internal-engine/308025-ls2-throttle-body-90mm-fast-intake.html
https://ls1tech.com/forums/generation-iv-internal-engine/242952-ls2-tb-help.html
https://ls1tech.com/forums/generation-iii-external-engine/220407-pics-ls2-tb-00-vette.html
https://ls1tech.com/forums/generation-iv-internal-engine/237344-opinions-ls2-vs-lsx.html
