Finished my header install!!!
Old Feb 11, 2006 | 02:13 PM
99M6Z28's Avatar
Default Finished my header install!!!
I finished the header install this morning. I expected it to be a pain in the *** but it was really easy. The entire install and the y-pipe only took 4 hours. Hell I even changed the spark plugs. Granted I had access to all kinds of tools and a lift. My father helped me out and everything went really smooth. The only problem is the y-pipe bangs. It feels like a something grinding when I let the clutch out which I assume that is the pipe vibrating off the floor. Will a piece of heater hose work for now till I can get the bump stop from Thunder Racing? I don't really want the hose to melt or anything. Will it melt? Anyway, the car sounds awesome and it has a lot better throttle response. Only wish I could have left it open headers. Now that is awesome!!!! I really havent got on it hard yet to see if there is a seat of the pants diffrence. All I have to say is Pacesetters install rocks!!!
Thanks to everyone for the advise and help given in my selection!
Old Feb 11, 2006 | 02:34 PM
Luna's Avatar
Haha I just installed my pacessetters last night and couldnt believe how easily they went in, I also have a nasty problem with the Y banging bad, I wonder what kind of temp fix is there untill I get that mufflex bump stop
Old Feb 11, 2006 | 02:42 PM
99M6Z28's Avatar
I am thinking maybe a piece of heater hose but i don't know
Old Feb 11, 2006 | 03:08 PM
RoastEmSS's Avatar
hows the ground clearance?
Old Feb 11, 2006 | 03:40 PM
99M6Z28's Avatar
The ground clearance is great. I actually gained clearance over my Mac ORY-pipe and stock manifolds. But like I said, I still need to do a little more work with it since it is banging pretty bad. I just put a piece of heater hose i there where it hits and now there is a bad vibration because it is like solid between the pipe and the floor.
Old Feb 11, 2006 | 03:48 PM
RoastEmSS's Avatar
well if it has that good of clearance then lower the pipe some wear it bangs,unless you already welded it, thats what i had to do
Old Feb 11, 2006 | 03:52 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Originally Posted by BLACKNREDSS
well if it has that good of clearance then lower the pipe some wear it bangs, thats what i had to do
I agree. If you can lower the y-pipe, I'd do that first. You don't want to have to engineer up something that could potentially catch on fire, or something that could work loose and fall off when you're at the dragstrip.
I have the much-hated (so it seems) SLP LT's, Speed Inc. Race pipes, and SLP Y-Pipe. The ground clearance is decent (my car isn't lowered), and the Y-Pipe doesn't rub anywhere.
Old Feb 11, 2006 | 04:00 PM
Full-Force's Avatar
A piece of heater hose will work. Best bet is to clearance the floorpan right where its bumping and install some poly motor mounts which should have been done while the exhaust was off.
Old Feb 11, 2006 | 05:14 PM
KrazyDan's Avatar
mine hit the floor board for about 2 weeks, then fixed it self. its been fine ever since( about 1 1/2 years). i guess i got lucky
Old Feb 11, 2006 | 05:15 PM
TheSilverOne's Avatar
ding ding ding
Old Feb 11, 2006 | 05:40 PM
99M6Z28's Avatar
Yeah, I didn't weld it, I used 3 in band clamps. I am gonna put it on the lift again monday afternoon and see if I can loosen it and re-adjust it a little to help the banging. Shouldnt be that big a deal.
