View Poll Results: what's your choice will be ?
True Duals
209
65.11%
ORY & Catback
112
34.89%
Voters: 321. You may not vote on this poll
poll: true duals VS Ypipe & cat-back?.....
Old Feb 21, 2006 | 09:15 PM
  #61
blkZ28spt's Avatar
Originally Posted by spun03cobra
If there was a real true dual exhaust set up that could be ran all the way out the rear of the car I would do it, I have looked into it
You can do a real true dual all the way out the back. Problem is most are custom in house. Have you seen Basani's system? Looked into having an exhaust shop fab it up for you?
but would rather do the single just due to laziness.
That's a better excuse.
Old Feb 21, 2006 | 09:19 PM
  #62
00SS4780's Avatar
I have a local friend who had a custom td x setup under the axle. He had some bolt-on's and a T-rex cam. He made 406 with it. He then decided to put on a y-pipe system like mine and a cutout. Because of ground clearence issues. He redyno'd the car and made the same amount of hp. Now the x wasn't a brand name but still I was shocked it made the same.
Old Feb 21, 2006 | 09:21 PM
  #63
blkZ28spt's Avatar
What Y-pipe/merge? What X-pipe?
Do you have graphs? How did the power under the curve compare...?
Old Feb 21, 2006 | 09:23 PM
  #64
00SS4780's Avatar
The Y pipe was a mufflex like the one posted with a hooker aero muffler. I'll look and see if I can find the graphs. I't might take a minute.
Old Feb 21, 2006 | 09:38 PM
  #65
00SS4780's Avatar
I found the comparison graph he had but it was a red x. I emailed him to send me a pic of it and I will post it.
Old Feb 22, 2006 | 04:25 AM
  #66
edwardswb's Avatar
QTP LTs+3"Xduals+dual cutouts+sweetthunders+stainless CME = friggin PIMP
Old Feb 22, 2006 | 07:16 AM
  #67
SouthFL.02.SS's Avatar
!LS1 11 Second Club
That would be a very figh flowing combo.
Old Feb 22, 2006 | 11:16 AM
  #68
01 Trans Am's Avatar
Is it really necessary to have dual cutouts, or a cutout at that w/ true duals?
Old Feb 22, 2006 | 11:52 AM
  #69
blkZ28spt's Avatar
Not for most of us.
If you only have 2.5" pipes, or a 2.5" ID muffler (like sweet thunders) and you are making >450 rwhp you might consider it, but even then it shouldn't be much of a difference at all.
Old Feb 22, 2006 | 11:55 AM
  #70
A-Bomb's Avatar
TD's all da way.
Old Feb 22, 2006 | 11:57 AM
  #71
all right, thanks!
Old Feb 22, 2006 | 06:20 PM
  #72
00SS4780's Avatar
I watched a local guy here put dual cutouts on his car TD setup with bullets. He lost I think around 5hp and 6-7tq with them open. He actually ran the car with the cutouts open to start with and then the next pull he closed them up.
Old Feb 22, 2006 | 07:39 PM
  #73
Louie83's Avatar
Originally Posted by SouthFL.02.SS
I don't know. All I know is that a good Y-pipe and a good catback made lots of power on my old car. I'd rather have a 480rwhp car with good ground clearance, a good, tolerable exhaust note than a 490rwhp car that can't make it up my driveway, smells like a gas station and that I can't have a conversation in, yet sounds mean as hell. It's all in what you want. I just thing MANY people are quick to rule out a Y-pipe's potential.
And, as for the sound mean as hell factor, I ran dual elect. cutouts and still had better clearance than the duals.
I was starting to think that I was the only one...
Old Feb 22, 2006 | 08:04 PM
  #74
00SS4780's Avatar
Ok here it is.
The red is TSP duals with bullets
The blue is hooker muffler and Mufflex merge or y
Old Feb 23, 2006 | 03:52 AM
  #75
300bhp/ton's Avatar
Cheers for posting that dyno chart. It just goes to show that sometimes mass public opinion isn't always correct
I would think this is due to one of two reasons. First off lots of people put the cutouts before the mid pipe, thus totally removing the scavenging that can be achieved with it. The other thing it the exhaust pressure wave, the cutouts may have been having a negative affect on it.
Old Feb 23, 2006 | 04:18 AM
  #76
UL LOSE's Avatar
Racer
1 7/8 Kooks LTs+3in y+2 1/2in GMMG=48rwhp
And sounds as sweet as any other ls1
Old Feb 23, 2006 | 05:42 AM
  #77
MeentSS02's Avatar
Kleeborp the Moderator™
Ok here it is.
Was each system tuned for optimum performance though? And I don't mean the shitty "pro" dyno tunes either where they start fudging numbers to get what they want.
Old Feb 23, 2006 | 05:54 AM
  #78
00SS4780's Avatar
No these had tunes on them but nothing in the way of fudging. It was with a stock geared M6 with 17" ZR1 wheels and no messing with air pressure. Now as for the dyno it was done on. Well it was just a local exhaust shops dyno and I am not sure if it is actually calibrated right. The A/F always seem to be way off with every car that we have had on there. But nothing was put in the dyno to change the diffence in outputs of the systems.
Old Feb 23, 2006 | 06:02 AM
  #79
MeentSS02's Avatar
How exactly was it tuned (or who tuned it)? Provided it was the same wideband each time, that would mean there is a difference that I would say is in favor of the y-pipe setup, and could account for the similar numbers. That is the only thing that is raising flags in my head with the two graphs.
Old Feb 23, 2006 | 06:09 AM
  #80
00SS4780's Avatar
It was the same tuner and the same dyno. All I am saying is I'm not a fan of the place we went to as far as a nice dyno goes. None of the numbers were altered any. This isn't my car. Yes the Y is alittle leaner but the lines still flow even with each other. I was just posting this to show what I had seen. If I wasn't there I would have called BS. But I was at both pulls and I couldn't believe it.
