Connecting the Electrical portion of a Cutout
Old Feb 19, 2006 | 12:30 PM
DaGeneral's Avatar
Default Connecting the Electrical portion of a Cutout
I bought a car with an electric cutout which did not have the electrical portion of it hooked up. I have the wires and switch - the guy said he didnt have any time to install it -.
I dont have instructions and was wondering if it was easy to install with the battery or if that is too much voltage?
It is a QTP Electrical cutout. TIA.
Old Feb 19, 2006 | 01:04 PM
2001NBMZ28's Avatar
I connected the red wire to my radio fuse (switched power source) and for the ground the black wire off the cig lighter. You can also use the pink wire behind the TCS switch for power. I have their instructions if you need more info.
Old Feb 19, 2006 | 01:05 PM
DaGeneral's Avatar
If you can please give me more info...thanks
Old Feb 19, 2006 | 01:15 PM
2001NBMZ28's Avatar
What I posted was just the connections for the switch power/ground. Everything else is installed right?
Old Feb 19, 2006 | 01:22 PM
DaGeneral's Avatar
The cutout is already on the car. WHat I have are only the connections to the cutout and the ground, red, and black wires along with the switch.
Old Feb 19, 2006 | 01:39 PM
2001NBMZ28's Avatar
The switch side of the cable has a connector - plugs into the connector coming off the plate/motor, routed into the car through the grommet under the rear seat. All you need is a power source and a ground connection to the wires coming off the switch - you'll have to extend the wires with a butt splice.
Old Feb 19, 2006 | 01:57 PM
2001NBMZ28's Avatar
Hey, I should've offered earlier...if you want to PM me an address I'll be glad to send you the 3 page instructions that came with mine.
Old Feb 19, 2006 | 01:59 PM
DaGeneral's Avatar
Im gonna call the guy to see if he has them and if not I'll let you know. Thank you.
