Exhaust leak...help!
Old Feb 27, 2006 | 11:00 PM
jlashley2001ss's Avatar
Default Exhaust leak...help!
I had my car taken in today for rear end fluid check and header bolts tighten up and the mechanic told me that I had a slight leak around the Y pipe clamps. Would it hurt to have it that totally welded up? I was thinkin of getting a exhaust shop to just weld it up completely and prevent any leaks. What u guys think?
Old Feb 28, 2006 | 10:47 AM
conan's Avatar
Are you talking about welding the Y pipe to the headers?? If so I woun't go that way, If you ever have to remove the headers it would almost be impossible with out cutting it apart. Try getting some stainless band clamps, they work verry well. I've taken mine apart multiple times and I dont have any leaks.
Old Mar 1, 2006 | 11:51 AM
im talkin about the clamps on the catted y pipe from TSP that fits onto my Pacesetters. If somebody that has the catted y pipe from TSP help me out guys.
Old Mar 1, 2006 | 11:54 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Band clamps are the way to go. If you are gonna weld up anything...put some flanges on your y-pipe and headers, then get some of those dead-soft aluminum gaskets and you should be set for a leak free ride!
Grimes's Avatar
like conan said, don't weld the entire thing up. It will be hell if you need to get the headers or catback off!
Old Mar 1, 2006 | 04:42 PM
Fill me in on these flanges and dead-soft gaskets. Where can i get these and who you think would be able to install this? I know i sound like an idiot asking this but just want to be 100% sure!! Thanks guys
Old Mar 1, 2006 | 09:00 PM
TTT guys!
Old Mar 2, 2006 | 09:58 AM
/\ /\ /\ /\ To the top guys! Read comments above
Old Mar 2, 2006 | 10:37 AM
conan's Avatar
http://www.jegs.com/webapp/wcs/store...1535&langId=-1
Here are some flanges that orange was talking about.
Old Mar 2, 2006 | 12:34 PM
Which size would i need 3" collector to 3" system ? And this eliminates clamps correct?
Old Mar 2, 2006 | 12:50 PM
conan's Avatar
My Kooks lt's and ory are both 3" . Your pacesetters should be the same . Might want to call tsp to make sure on your Y. Yes the flanges will eliminate the clamps.
Old Mar 2, 2006 | 01:39 PM
TheBlurLS1's Avatar
That's what she said...
I would just get some band clamps from an autoparts store. You can take a bunch of layers of aluminum foil, fold it a few times, and wrap it around the overlap, then put the band clamp on top of that. It will squeeze into the crack and seal her up.
I'm thinking about doing this to my header-exhaust joints this weekend.
I'm about | | that close to calling the noise that i have a result of the .600" camshaft though.
