port your throttle body yourself
Old Mar 3, 2006 | 11:04 AM
Lawnboy's Avatar
Restricted User
Default port your throttle body yourself
I have a ported stock throttle body, The ridge-lip has been removed and inside the throttle body has been polished up.
but i would like to also do the throttle shaft mod,
I am not realy sure how to do it,
can some one help me out , or give me a link to DIY porting the Stock LS1 throttle body
thank you for your help
Old Mar 3, 2006 | 11:58 AM
thunderstruck's Avatar
first off, remove the throttle blade and then mark the shaft where it is even with the wall of the throttle body, then remove the shaft and cut only the outer half (on both sides ) of the shaft. then reinstall shaft and check to make sure it is flush. then reinstall the blade & new screws, then trim down the screws. thats a pretty rough overview.
Old Mar 3, 2006 | 12:45 PM
Lawnboy's Avatar
Restricted User
is there a link on how to do it step by step?
and so you dont touch the back of the throttle shaft at all, mine has been grinded down in the areas around and between the blade screws, the front and the rear of the throttle shaft
Old Mar 3, 2006 | 01:05 PM
dont think i have seen a link for this mod, but will check around
i only did the front side of the shaft to try and keep it as strong as possible
Old Mar 3, 2006 | 01:19 PM
http://www.phantomss.com/camaro/portedtb/index.shtml
thats not a how to, but has some pictures of how most people do it
Old Mar 3, 2006 | 01:29 PM
theinstag8r's Avatar
here you go, the one i used
http://geocities.com/tc3_002/
Old Mar 4, 2006 | 05:21 PM
Lawnboy's Avatar
Restricted User
thany you very much
Old Mar 4, 2006 | 08:33 PM
Bo White's Avatar
My crash course is in my sig.
Old Mar 4, 2006 | 11:22 PM
Lawnboy's Avatar
Restricted User
what size metal tubing did that guy use for the IAC and breathing opening,
awesome job!
