pacesetter nightmare!
Old Mar 5, 2006 | 09:43 AM
Charlie@LsXperts's Avatar
Default pacesetter nightmare!
i installed my pacesetters yesterday by myself and it was a pain in the *** gettin the stock manifolds off one of my head bolts towards the back didnt go in all the way but i couldnt see it so i kept torquin and i look back there when it got really tight and its still a 1/4 inch out???? i may have to tap the head what do yall think, it sounds terrible
Old Mar 5, 2006 | 09:49 AM
LS69TA's Avatar
Yea, sounds like you'll have to tap that hole, maybe even helicoil it if it's bad enough. It's always a rear bolt for some reason..can't be up front where you can get to it easier.
Old Mar 5, 2006 | 09:54 AM
you can reach the rear ones better, when you have air and all that CRAP i love the way it sounds its just that you can hear the poppy header leak, i didnt think one bolt would make a difference. considering there is 1 on 1 side of it a 2 on the other.
Old Mar 5, 2006 | 12:07 PM
HottLS1Z's Avatar
Or you can take the bolt back out and put washers on it so they press in on the header when the bolt is in a s far as you had it before....thats what a kid aroud here did and He says it worked, I saw the bolt half way out with washers on it but he has no leaks. Depends how fast of a quick fix you want.
Old Mar 5, 2006 | 03:57 PM
thats what i did this mornin i still hear a wierd sounding leak i think it may be the AIR tube?
Old Mar 5, 2006 | 04:12 PM
SVThis's Avatar
i wouldcall that a header bolt nightmare and not a pacesetter nightmare
Old Mar 5, 2006 | 04:35 PM
Danny2tek's Avatar
^yea I thought it was something that pacesetter was at fault
Old Mar 5, 2006 | 09:38 PM
Redneck Z's Avatar
I just finished helping a friend install hooker longtubes. We ran into the same problem, and used a few washers under the bolt. This worked great and there are no leaks.
Old Mar 6, 2006 | 10:46 AM
01formula6's Avatar
Same thing here. Just use some washers and you will be fine.
