Tech help please
Old May 30, 2002 | 01:55 PM
ASR OFF's Avatar
Default Tech help please
How good of a mod is the 160 or 180 deg. thermostat? How does it exactly keep the temp down?
Old May 30, 2002 | 02:11 PM
Xsta Z 28's Avatar
Default Re: Tech help please
The thermo, alone in our electric fan controlled cars won't do anything to keep the car cooler.
If you install a cooler thermo, and either reprogram the fans to turn on sooner or install a fan switch will keep the car a little cooler. It is a negilgable amount on the OEM temp gauge.
I have the 160* thermo and the fans programmed to 180* and the car stays a little bit cooler. Every little bit helps. I didn't have the fans programmed to 160* since I felt they would run absolutely all the time.
Old May 30, 2002 | 02:14 PM
ASR OFF's Avatar
What did you use to reprogram the fans? HPP3?
Old Jun 6, 2002 | 06:07 AM
WILWAXU's Avatar
ttt
Old Jun 7, 2002 | 02:45 PM
haole_boySS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ASR OFF:
<strong>What did you use to reprogram the fans? HPP3?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can use the HPP3 or LS1 Edit. Or you can buy the SLP fan switch, or just make your own. There are a few write ups out there.
Like was said before, setting your fan temp too low will have the fans running all the time. That would annoy the hell out of me.
I have the switch and just turn it on and off when I want.
Andy
