FLP Header banging > Is an engine torque strap the fix?
Old Jun 15, 2002 | 08:32 PM
Tin Indian's Avatar
Default FLP Header banging > Is an engine torque strap the fix?
I still continue to hear of people that have banging with FLP headers, even though FLP [said] they re-designed these more than a year ago in order to fix this problem.
Anyone feel that an engine torque strap would keep the headers from banging the floor board?
Thanks,
Ron
Old Jun 15, 2002 | 08:46 PM
Sears's Avatar
!Dial-up Director
Default Re: FLP Header banging > Is an engine torque strap the fix?
I know it's ghetto but a little piece of heater hose screwed in the floorpan works. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> A torque strap would be a little overkill just to fix that IMO.
Justin
Old Jun 15, 2002 | 09:23 PM
jimmypop13's Avatar
My FLPs are going in Monday, I'll let you know if mine bangs or not but here is the fix with the heater hose, it's alot easier than I thought when someone described this once:
http://www.thefbodyshop.com/technica...m?pgFix=flpls1
Hope this helps
Chris
<small>[ June 15, 2002, 09:24 PM: Message edited by: jimmypop13 ]</small>
Old Jun 15, 2002 | 11:16 PM
Tin Indian's Avatar
I continue to be amazed that a $1300 set of headers needs a piece of rubber heater hose to stop from banging. And FLP posted right here on LS1.Com more than a year ago that they fixed the banging problem. Wish I saved the post.
Turbo Buick folks have been useing an engine torque strap for years. In fact, you would be hard pressed to find a lightly modified GN without one. Just thought it may put a stop to these FLP banging problems and keep the motor from moving so much on the sloppy GM engine mounts.
Ron,
Old Jun 15, 2002 | 11:35 PM
Sears's Avatar
!Dial-up Director
I have had both the old and new FLP y-pipe. To allow more clearence on the drivers side from the floorpan, the v-flange is angled down on the rear off the ORpipe/cat. You sacrifice more ground clearence and it still bangs. I prefer the original design ( good for lowered cars like me ). The v-flange is what hits the floorpan.
Old vs New FLP y-pipe
The new style one is black (uncoated one).
Justin
Old Jun 16, 2002 | 02:42 AM
346cubes's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Jsears8 The new style one is black (uncoated one).</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did FLP or you change the collector?
Old Jun 16, 2002 | 10:49 AM
Blue Fire's Avatar
kool where can you by this strap at¿¿¿ <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 16, 2002 | 11:33 AM
Sears's Avatar
!Dial-up Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 346cubes:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Jsears8 The new style one is black (uncoated one).</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did FLP or you change the collector?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">They changed it as it was requested.
<small>[ June 16, 2002, 11:34 AM: Message edited by: Jsears8 ]</small>
Old Jun 17, 2002 | 12:14 AM
Blue Fire's Avatar
is that for the 2001 also now i thouight from a burn out i heard a little nocking under the car but i thouight that was the tire's or poor lower control arm's?????? i looked under there and i saw a lot of clearence with No problem would it be the header's nocking under the car¿¿¿¿¿¿ seem's to happen when i do a burn out.....
