ATI Pulley better than ASP or about the same?
Old Jun 16, 2002 | 09:37 AM
99 Black Bird T/A's Avatar
Default ATI Pulley better than ASP or about the same?
Anyone know?
Old Jun 16, 2002 | 10:09 AM
Blue Fire's Avatar
Default Re: ATI Pulley better than ASP or about the same?
i dont have the ASP's but i heard thay are top of line that's what im going with anyway <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> just make sure you have enouif room under there so you can get that belt off and have the space <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> got thoe's on order to <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )) <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 17, 2002 | 12:59 AM
quickWS6's Avatar
The ATI is the best. Many people who are going extremely quick are using the ASP, though. However, for me, it was worth the extra money for the peace of mind the ATI will bring. If you develop any type of shudder in the bottom end, the ASP will not be able to dampen it. The ATI will be. That was all that was needed for me to sell my ASP and purchase the ATI.
BTW, the ASP is 25% underdrive, the ATI is 10%. However, I believe the ATI may be lighter, so the same performance gain is realized.
Old Jun 17, 2002 | 04:24 AM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99 Black Bird T/A:
<strong>ATI Pulley better than ASP or about the same?
Anyone know?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ATI is the better and safer pulley for the motor.
Old Jun 17, 2002 | 07:38 AM
MIGHTYMOUSE's Avatar
ati is a damper and pulley, asp is just aluminum, no damping help which is why its really not good for the engine because it doesnt soak up any vibration.
Old Jun 17, 2002 | 08:17 AM
SSINFUL's Avatar
The ATI Super Damper is SFI certified. You gotta have one if yer fast enough anyways...
I'm not, but I'm damned tired of paying for rebuilds 'cause of broken timing chains.
Old Aug 10, 2002 | 10:19 PM
highgmc's Avatar
i am about to order, which to get?
sounds like the asp may cause problems?
Old Aug 10, 2002 | 10:51 PM
StevieZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">ati is a damper and pulley, asp is just aluminum, no damping help which is why its really not good for the engine because it doesnt soak up any vibration. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is wrong. The latest ASP pulley that is out is also a dampener. It is the old model that wasn't.
Old Aug 11, 2002 | 03:27 AM
MY99TAWS6's Avatar
I emailed asp and asked some questions..they said the ls1 doesn't use a balancer it uses a damper..and they said there pulley is a damper and it is only one pound lighter than stock..and don't think it is aluminum..might be aluminum center.I have no problems with mine..noticed no difference in vibrations and no knock retard on last quartermile run.I think the ati makes sense on race cars..cars that run at high rpm continuously like circle tracks..for a street car that is only at 6500 for a second or so can't see the point..lots of people run the asp with no problems..so the newest one maybe be a bit of an improved design..thats fine since I just got mine a few weeks ago.Only thing I know is my car ran its best time so far with the pulley.I also run the katech jwis timing chain..same chain as c5r race cars..doubt very much it will break.
Old Aug 11, 2002 | 03:36 AM
Raughammer's Avatar
D(irecto)r Pepper
The ASP pulley has done us right and the fastest of the fastest use it. (street guys that is)
I picked up two tenths with mine and no other changes....all in the same weekend... same weather.
ASP is the ONLY pulley I recommend.
Old Aug 11, 2002 | 08:18 AM
How do you tell the difference in the old ASP design and the new one?
Anyone know the actual performance difference between the ASP and the ATI?
Have to admit I'm leaning toward the ATI cause it sounds like it's better long term for the engine.
Old Aug 11, 2002 | 09:15 AM
NastySSoo's Avatar
Ditto what Raughammer said!
Old Aug 11, 2002 | 10:45 AM
Larry's Avatar
ASP is a harmonic balancer. It has an inner hub made of aluminum for a reduction in weight and an outer heavy ring of steel to eliminate harmonics. 10% reduction from the ATI is not enough to get any appreciable hp gains. Go with the ASP! Tried and proven...
<small>[ August 11, 2002, 10:48 AM: Message edited by: Larry ]</small>
