Flattening Pipes
The exaust passes thru the same volume its just oval Vs round....
Here is a chart of roughly equivalent oval tube that corresponds to a fully round (nominal size) tube, from this site:
http://www.burnsstainless.com/OvalTu...valtubing.html
Oval Tubing Dimensions
Nominal Size: 3"
H x W: 2 1/8" x 3 1/2"
Nominal Size: 3 1/2"
H x W: 2 3/8" x 4 1/8"
Nominal Size: 4"
H x W: 2 1/2" x 4 3/4"
Interesting idea though.
I would agree with NHRAMAN and guess if any losses on a med or mild build up it wouldn't effect you.
if you take a 2x2 square and make it a 1x4 square the area is the same
Oh and the sound, while i was researching all that y-pipe crap in oval and round etc, i spoke to a few of the people at dr.gas and other shops and they all told me the oval would make it sound higher pitch, would make it scream more bla bla, ...which is why i wanted to pursue it in the first place becuz of what i thought it would sound like....jus imagine high pitch sounding LS1's, picture something like a ferrari+nascar sound comin out of ur tips..sweeeeeeet
ill do it someday, probably when i turbo the car and destroy some of the exhaust piping lol
4x4=16, 5x3=15, 6x2=12, 7x1=7.
Do you understand what I'm trying to say.
lol
you cant possibly be serious?!? the 2x2 square has a circumfrence of 8, the 1x4 has a circumfrence of 10. It wouldnt even be the same tubing!Anyway, yes, as you flatten the round pipe, the cross sectional area lessens. Imagine if you continues to crush it till it was completely flat. How much area would that be? Probably wouldnt flow as well as the original pipe, huh?
That being said, most of our exhausts are way overkill for our applications. You can easily get away with crushing some areas for added clearance.
Here's the formula for fiuring out the cross sectional area of a floval pipe (flat oval)
Original 3" tubing has an area of 7.065 (radius x radius x pi) and a circumference of 9.42 (diameter x pi)
Now lets crush it to 2 inches high. Now the easiest way to think about a floval pipe is to break it into easier shapes. Lets picture it as a rectangle with a half circle on each side. First lets figure out the area of the two half cirlcles (equal to one whole circle) on each side. 1 x 1 x 3.14 = 3.14. So the two half circles have an area of 3.14 sq. inches. Now lets find the circumference. dia x pi gives us 6.28. The circumference of the pipe wont change when you flatten it, so lets take the original 9.42 and subtract 6.28. This gives us 3.14 inches of circumference left over. Half of this will be the flat spot on the top, and half on the bottom, so lets divide by 2. (3.14 / 2 = 1.57) Now lets figure out the rectangular area between the two half circles. We know the pipe is 2" high now, and that we've got 1.57" of flat on the top and bottom, so 1.57 x 2 = 3.14. Now all we have to do is add the area of the two half circle sections to the area of the center rectangular section. 3.14 + 3.14 gives us 6.28 cross sectional area of our crushed pipe, where as the original has 7.065. See the difference?
Of course this example does not take tubing wall thickness into consideration, but you get the idea.
Using your own formulas, which as far as I can tell are indeed correct, a 4" round tube has a cross sectional area of 12.56 square inches. That same tube flattened to 2" has a cross sectional area of 9.42", which is indeed greater than a 3" round tube, yet provides an additional inch of ground clearance.
There's still the issue of that 4" oval pipe having a greater surface area to volume ratio than a round pipe, which will create a greater resistance to flow as well, but the numbers tell me pretty confidently that it will still be far better than the stock exhaust, and absolutely viable for anyone looking for an upgrade that doesn't impact ground clearance.
Something like this would have to be custom made though, so you're either looking at paying somebody to do it for you, or putting in the time and effort to do it yourself, assuming you have all the equipment to do it properly.
**EDITE**
Sorry, hadn't really read the whole thread. I realize now you're responding to later posts regarding cross sectional area decreasing when you flatten a given pipe. Flattening a larger pipe is still a viable option though, as the numbers indicate.
**EDITE**
