throttle body ?
Old Jun 17, 2002 | 01:22 AM
ZR2877's Avatar
Default throttle body ?
would a ported stock throttle body 85mm perform the same as a 85mm slp or 85mm granatelli is there any differance. does polishing one make a little difference or not thanks in advance.
Old Jun 17, 2002 | 05:23 AM
z28man's Avatar
Default Re: throttle body ?
im sure the perfomance is going to be about the same! svae yourself some money and go with thunder racing, have them do a core swap on your stock throttle body! you'll get just about the same performance and about 150.00 dollars cheaper!
bbk: about 400.00 thunder coreswap:300.00 core is 200.00 ~ check out thunder racing website good people!!
Old Jun 17, 2002 | 07:36 AM
MIGHTYMOUSE's Avatar
slp and granatelli make mass air sensors at 85mm, not throttle bodies
do you want a larger throttlebody or maf housing?
Old Jun 17, 2002 | 05:17 PM
2001CamaroGuy's Avatar
I have never seen an 85 mm TB.....(does not mean they don't exsist)......where do people keep getting this from?
BBK is the only company I know of making a "larger" (80 mm) TB.
MAF is different than TB
Old Jun 18, 2002 | 04:38 AM
ZR2877's Avatar
i want both a bigger throttle body and maf i talked to someone yesterday they said stock tb is 70 mm and you can get it bored to about 75 i beleive he said the other after market ones are bored but still neck back down to like 73 so maybe i should get the factory one bored whats the best maf for the $ and how much diff in hp if i add tb + maf thank you all
Old Jun 19, 2002 | 01:08 PM
SStrokerAce's Avatar
IMHO, the throttle body is a better mod to actually gain hp over the MAF. Not to say the MAF doesnt work.
The stock throttle plate is 75mm, the BBK is 80mm. The opening you are talking about in the stock throttle body is 70mm and it is the silencing lip in the stock throttle body that is this size(both f-body and C5) Most ported stock throttle bodies are bored out to 75mm and then blended to achive a more laminar flow path for the air.
<small>[ June 19, 2002, 08:41 PM: Message edited by: SStrokerAce ]</small>
Old Jun 19, 2002 | 06:25 PM
WILWAXU's Avatar
SStrokerAce: If you want to advertise then you will need to become a sponsor.
Old Jun 20, 2002 | 01:07 AM
Jantzer98SS's Avatar
The stocker is 75mm as is the ported units, but the inside ridge is removed. The MAF should be one of the last things you should change, I'm running 10's on a stock MAF as are others. The TB's usually show gains of 5-10RWHP depending upon other mods. And they CAN also be an appearance mod. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Here a couple pics of a stocker and my ported/powdercoated TB's. You can see the difference between a ported and stocker TB.
http://community.webshots.com/photo/...39965213mgXNOw
http://community.webshots.com/photo/...39964194qAuxnG
http://community.webshots.com/photo/...40041067YCbsEW
Old Jun 22, 2002 | 12:16 AM
purevilss's Avatar
Jantzer, who can I contact to get my throttle body done. I am going to have my car down the first week or so of July and thought it would be a good time to send in my part for work. Could you email me with any contact info that you know, at purevilss@aol.com
Thanks,
Old Jun 23, 2002 | 02:22 PM
Scott you have mail!
