PaceSetter install?
Old Mar 16, 2006 | 12:10 AM
ryanfx's Avatar
Default PaceSetter install?
Anyone have a link to an install guide? I'm putting longtubes in this friday on my 01 TA and I just wanted to look through everything. I've done a ton of searching but didn't find a step by step how-to.
Old Mar 16, 2006 | 12:25 AM
WhiteKnightZ28's Avatar
Tech Resident
Its in the sticky... you know, the one that says "please read before posting"
http://www.geocities.com/foff667/98Camaropg4.html
Old Mar 16, 2006 | 12:38 AM
ryanfx's Avatar
knew I saw it somewhere =p
thanks a bunch
Old Mar 16, 2006 | 04:49 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just get that bitch a few feet in the air!
Old Mar 16, 2006 | 07:17 AM
yak's Avatar
yak
I can do a set of pacesetters with the front wheels about 5 inches off the ground if even, they are easy as pie
pull coil packs plugs and wires
disconnect o2 sensors,
pul y pipe
unbolt manifolds
put headers in
get bolts started, install y pipe,
tighten header bolts down
reinstall o2s
put coil packs plugs wires back
start it up, check for leaks
wlet that bitch smoke with the hood up for a few minutes
drive it like you stole it
