Post pics of you catch can
Well im ditching the stock valve covers for these.....
So theres no place for a breather on these......
and i wont have a PCV system at all so ill be needing a catch-can/breather setup and yes alot of it is for looks..... to finish the setup.
Kyle
it's only like $25
Pic.....????? I take it its plastic......... I wanted aluminum to match everything else........
Yeah i saw those and i didnt want plastic and they only had one -10an fitting on them. I needed ne frm each side... since im running dual -10an lines from each valvecover.....
That catch-can i bought has dual 3/8 npt fittings so i can use a 3/8 npt to -10an fitting for it.
Kyle
Free
I'm putting it where the air pump use to be
that where he has his and he has no problems
http://www.cardomain.com/member_pages/
heres allitle write up i did for those asking what they do...
http://www.ls2.com/forums/showthread...hreadid=369068
i was really surprised at how well it works.. the lines are now absolutely spotless.
i now personally think that water/oil separator with the special element these have is the best solution vs. the screens etc. that are in common catch cans.
my set up recently changed to adding this. mine is kida diff for the turbo set up. i'm pulling vaccum on the crankcase with mine.
Is that black sharpee?
