Post pics of you catch can
Old Jun 2, 2006 | 12:37 PM
  #61
bene's Avatar
Trunion King
Ha! I just bought a PCV made for LS1 trucks. A few people at LS1.com recommend me just buy this part instead of getting a catch can that will add more **** on the engine bay. I compare between the two and it make sense that the truck PCV should do the job preventing oil into the intake manifold.
Old Jun 2, 2006 | 12:52 PM
  #62
INMY01TA's Avatar
It doesn't.
Old Jun 2, 2006 | 06:17 PM
  #63
9silverbird8's Avatar
Originally Posted by INMY01TA
Just like my set up on the previous page. The LS6 valley didn't help me at all either.
I actually think the LS6 cover made things worse in my application.Therefore, Ill be picking up that Husky separator this weekend.
Old Jun 2, 2006 | 07:24 PM
  #64
bene's Avatar
Trunion King
It doesn't.
Have you tried this route?
Old Jun 2, 2006 | 07:31 PM
  #65
INMY01TA's Avatar
GM made the truck PCV valve the standard replacement for these cars at least 5 or 6 years ago. I remember reading bout it back then. That didn't help then people started doin the LS6 PCV swap (myself included). No success there either. If your gettin oil in the intake your best bet is a catch can. Good luck with it tho, there's always exceptions to the rule.
Old Jun 3, 2006 | 09:29 PM
  #66
bene's Avatar
Trunion King
GM made the truck PCV valve the standard replacement for these cars at least 5 or 6 years ago. I remember reading bout it back then. Good luck with it tho, there's always exceptions to the rule.
Catch can would probably my last resort also if this don't work, but like I was saying my original PCV have a bigger inlet orifice than the truck PCV (made for 2002-2004)and also the old PCV had something inside like a check valve or something. The truck PCV is just tiny canister with two holes, one on each end, one smaller than the other (inlet hole).
Old Jun 3, 2006 | 11:15 PM
  #67
BadAssFast's Avatar
I have nitrous solenoids stacked on the passenger side head at the tensioner. I have the AMW as well and plan on getting it tucked down where I can access the petcock through the access doors under the driving lights on my 2000 Camaro. Any photos of this area? Ideas on where to mount the can?
Old Jun 4, 2006 | 12:36 AM
  #68
SIC LSX's Avatar
I put mine under the fuses on driver side and had it hanging down to where the air pump is and when its time to drain oil out of it I pull 2 screws out where air pump is and easy accesses!
Old Jun 4, 2006 | 11:22 AM
  #69
Shockwave179's Avatar
I hate to threadjack alittle but I need ask a total noob question, can someone go over how you would hook a catch can up?
Old Jun 4, 2006 | 05:18 PM
  #70
bone324's Avatar
Whatever you want to catch, plug it in the middle of the line. PCV valve out of the crankcase into the catch can, out of the catch can into the throttle body.
Old Jun 4, 2006 | 09:33 PM
  #71
JoeMack's Avatar
Anyone try this one? Good Deal?
http://cgi.ebay.com/ebaymotors/ws/eB..._BIN_Stores_IT
Old Jun 5, 2006 | 12:43 AM
  #72
TheBlurLS1's Avatar
That's what she said...
Originally Posted by JoeMack
Damn that does look like a good deal!
Old Jun 6, 2006 | 01:44 AM
  #73
bene's Avatar
Trunion King
Well, just bought myself a husky homemade catch can just like stang killa sans braided steel hose, just regular 3/8" rubber tubes and fittings.
Old Jun 10, 2006 | 10:28 AM
  #74
Mr. Luos's Avatar
Originally Posted by orangeapeel
Anyone ever think of converting the A/C Dryer into a housing for a catch can? I figure that would be the best hidden stock setup you could have....only if you were !AC though. I would like to see this done.
Currently working on fabbing something up. I am not the best at coming up with a design though. Just don't have the imagination or something.
That is the location mine is going though. Just have to figure out how to mount it.
The dryer bracket was too big for my can, so I had to cut it down.
Old Jun 10, 2006 | 09:58 PM
  #75
Mr. Luos's Avatar
Got it.
Fairly clean install I guess.
Old Jun 11, 2006 | 01:37 AM
  #76
TheBlurLS1's Avatar
Originally Posted by Mr. Luos
Got it.
That looks very nice!
Old Jun 21, 2006 | 12:55 PM
  #77
SuperSporttruck's Avatar
This question is for anyone. When buying a compressor oil separator is it better to have a unit that is 22 scfm @ 90 psi with .01 micron filtering or a 57 scfm @ 90 psi with 5 micron filtering ability. So either better flow less filtering or less flow and more filtering. Thanks
Old Jun 21, 2006 | 01:01 PM
  #78
JoeyAnderson's Avatar
Check out my catch can:
Old Jun 21, 2006 | 01:09 PM
  #79
TheBlurLS1's Avatar
I've got the same one.
Mother nature is my new catchcan, never have to empty her out either.
Old Jun 21, 2006 | 01:24 PM
  #80
firehawk0623's Avatar
what are thay for and how do you put it in
