who has the supermaxx system?
Old Jun 12, 2006 | 06:55 PM
  #41
senicalj4579's Avatar
joe, i was dealing with rattling noises ever since i installed it. i just finally came up with something 2 days ago. what i did was i took some old trans cooler hose and wrapped it the full diameter around every part of the system that was hitting any metal. i then cut the hose and i took big tie straps and ran it through the inside of the hose around the exhaust pipes. works perfect. and yes i had the same problem with the passenger side cat. i did the same thing with the cooler hose there as well. i'll take some pics and show you what i mean
Old Jun 12, 2006 | 07:18 PM
  #42
joecar's Avatar
Okay thanks.
Old Jun 14, 2006 | 09:21 AM
  #43
joecar's Avatar
Last night, I loosened the collector flanges and all the clamps, pulled downward on the pipes so that the Y almost touches the sheetmetal cross-brace, made sure there was clearance in the following areas, then I tightened flanges/clamps:
- between driverside L-pipe and car floor rib
- between Y-pipe and driveshaft tunnel, especially on passenger side of tunnel
Seems much better, now it only bangs once when I shift out of Park.
Old Jun 15, 2006 | 12:38 PM
  #44
joecar's Avatar
Okay, got some banging if I step on it turning right from a dead stop;
sounds like the Y banging on the passenger side of driveshaft tunnel (only have 1/4" clearnace there);
minor readjustment/rubber required.
Otherwise I'm impressed, sounds good (even with stock catback) deep rumble, plenty of low end torque, seems to breathe easier at higher rpms.
Sets off car alarms very easily with just a light blip of the throttle; sounds almost like a big block.
Old Jun 15, 2006 | 07:21 PM
  #45
TexasVortexx's Avatar
Nice, do you have the capabilities of making a sound clip? From everything I have read so far this sounds like the system I will end up with.
Old Jun 16, 2006 | 09:49 AM
  #46
joecar's Avatar
My life is low tech (I don't even watch tv) (although I have a hi tech job ), so I don't have anything to record with; I'll see if my workmates can help me out.
Old Jun 16, 2006 | 09:57 AM
  #47
joecar's Avatar
Originally Posted by TheBlurLS1
I bent one of my old MSD's to see if it would clear a header tube friday. Friday night the car ran like death. Saturday morning I broke out the multi-meter and it ohm'd out some rediculous amount of resistance. It was also on and off. I would not recommend bending the MSD wires.
I ohmed the 4 wires I bent and they are at 28 ohms.
When I bent them, I carefully/slowly bent the boot using both hands, so it seems I didn't damage them.
Sounds like you somehow broke the core wire, will MSD replace it for you...?
Old Apr 8, 2010 | 06:06 PM
  #48
and back from the dead lol
hey joe you still got those on your car?
Old Apr 8, 2010 | 09:53 PM
  #49
joecar's Avatar
Yes, I got them on/off several times (can do it in my sleep now), being here in cali...
Old Apr 8, 2010 | 11:09 PM
  #50
I hear that. I had to take mine off a couple years ago so I could sell them and then sell the car. But im back with my 3rd ls1. Went with pacesetters this time. Installing the current made me remember how nice that expensive stainless system was lol.
Personaly I think this was the most underated header package. It should have been up there with kooks,arh,and qtp
By Brett Foote | 2026-06-04 05:00:17
