Why True Duals?
Old Jun 21, 2002 | 09:24 PM
TravWS6's Avatar
Default Why True Duals?
How come everyone wants true duals.. well i do to.. but doesnt all this mandrel bent Y pipe and cat backs have just as much flow.. i mean don't they make the same amount of power?? u might gain some low end torque when dumped before the rear axle right? help me out here.. if theres a increase it cant be no more then what 5 hp????i don't no.. just a guess.. wonder if anyone has dynoed true vs Y pipe?
Thanx
Old Jun 21, 2002 | 10:34 PM
Fulton 1's Avatar
Default Re: Why True Duals?
Two 2.5" dia. pipes will flow about the same as a single 3.5" dia. pipe. Two 3" pipes will outflow a single 4" pipe by over 10%. To get the most possible exhaust flow, a true dual with H or X-pipe is the best bet (especially if you can do 3"). The sound will also be different. The only drawbacks I can think of to true duals are the difficulty in routing on the F-bods and a bit of added weight (2 x 2.5" pipes = ~35% more steel than 1 x 3.5" pipe and 2 x 3" pipes = ~50% more steel than 1 x 4" pipe).
<small>[ June 21, 2002, 10:39 PM: Message edited by: Fulton 1 ]</small>
Old Jun 21, 2002 | 11:04 PM
Viper's Avatar
Sound - unlike any catback, nor reproduceable by one. imho
Old Jun 22, 2002 | 03:11 AM
TravWS6's Avatar
that helps.. but sure theres more flow? but how many horse does that equal? im guessing it would have to be mendrel bent for actual increases in power? i em still almost concidering duals.. but there are to many cons to it.. ground clearence.. how to make the back bumper look good with no tips.. getting a shop that will actually do a good job designing it. thanx again for clearing that up.. im not completly convinced on getting duals yet! hah but u got me closer.
Old Jun 22, 2002 | 10:42 AM
Ryan K's Avatar
Pathological Modifier
I think an honest projection of a true 3" dual setup is about 10-15 rwhp over a good flowing catback. The exhaust is almost always a bottle neck when you are talking about F-bodies. true 3" dual is as close as you can get to open exhuast and I hav seen cars pick up 20 rwhp from dropping the y-pipe.
Ryan K.
Old Jun 22, 2002 | 11:07 AM
Rpm2800's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TravWS6:
<strong>that helps.. but sure theres more flow? but how many horse does that equal? im guessing it would have to be mendrel bent for actual increases in power? i em still almost concidering duals.. but there are to many cons to it.. ground clearence.. how to make the back bumper look good with no tips.. getting a shop that will actually do a good job designing it. thanx again for clearing that up.. im not completly convinced on getting duals yet! hah but u got me closer.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The sound is alot different, and some like it better. (some don't)
As far as the back bumper issue, they can be made to run all the way back... unless you just want dumps.
Old Jun 22, 2002 | 04:58 PM
Supertrapped's Avatar
Speed freak
The routing is a little difficult. Not much room to work with under our cars. But after everything is said and done...you actually have more ground clearance. On the x-pipe system, the pipes tuck up. They don't hang down like y-pipe systems do.
Also...you actually drop weight switching from a catback system into a x-pipe system. You lose about 40-50lbs.
Btw...my exhaust consists of...MAC headers, no cats, Dr Gas true dual 2.5" x-pipe system, dual cutouts, Dynomax bullet mufflers, turndowns before the axle.
Old Jun 23, 2002 | 01:03 AM
2000LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DevilBird:
<strong>The routing is a little difficult. Not much room to work with under our cars. But after everything is said and done...you actually have more ground clearance. On the x-pipe system, the pipes tuck up. They don't hang down like y-pipe systems do.
Btw...my exhaust consists of...MAC headers, no cats, Dr Gas true dual 2.5" x-pipe system, dual cutouts, Dynomax bullet mufflers, turndowns before the axle.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So you did put those cutouts after the x-pipe. Sounds nice, any dynos yet???
 Michael S. Palmer
Old Jun 23, 2002 | 03:08 AM
INSSANE's Avatar
Or you could do 3" cutouts RIGHT after the headers and be done with it.
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Nick
Old Jun 23, 2002 | 03:28 AM
TravWS6's Avatar
thanx for all the reply's! ya i really want the duals when i go with headers.. i also want the x pipe.. but not sure about the cut outs still... proobly wouldn't want the exhuast running all the way back.. thanx
