How much did you adjust your MAFT after installing a ported Throttle Body???
After installing my Stage 2 Shaner TB, I'm running leaner up top. Before I was on the verge of too lean, but just right for maximum power. Now the TB has pushed me over the edge of leanness....and I'm getting some KR..and pinging.
I'm going to make a MAFT adjustment and see what happens but I was wondering how much you all adjusted your MAFT to correct the addition of a ported TB???
Re: How much did you adjust your MAFT after installing a ported Throttle Body???
I would try +10 % base and see where that gets you full throttle, should be close.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LS1derfull:
<strong>I would try +10 % base and see where that gets you full throttle, should be close.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My base is fine...it was at +10% to begin with..just trying to figure out how much I need to adjust my WOT....I was +10% base -8% WOT.....and I'm starting to scale back.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nic00Z28M6:
<strong>You shouldn't have to make any adjustments. If more air is being allowed in the TB, then that extra air is being read by the MAF as well.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would have tended to agree with you, but it is causing me to run leaner for some reason. No leaks or anything like that. Scaling back my MAFT's WOT setting from -8% to -6% cut my KR by 75%....I'm gonna wait for it to adjust some more and go from there.
