underdrive pulleys
Old Mar 20, 2006 | 09:40 PM
prostock_bigblock's Avatar
Originally Posted by 98camaroLS1M6
What material is the march made out of and what would make it better than an ASP pulley. Would the gains be more or less than an ASP?
The ASP is probably the lightest compared to others, but is not known for it dampening ability. I dont know but I am leaning towards the March damper as the best in damping and it doesnt throw belts as others.Furthermore,the march has a fluid based center, which will not cause spark sensors to retard the timing which results in power loss .
which material? not really sure.
Old Mar 20, 2006 | 09:50 PM
98camaroLS1M6's Avatar
Does the slp have a good dampening ability? Also, is the march lighter than stock?
Old Mar 24, 2006 | 12:33 AM
Justin00SS's Avatar
I'm thinking about ordering one from TSP.
Old Mar 24, 2006 | 12:41 AM
99camarosupersport's Avatar
yes its lighter, atleast that's what logic tells me from what i've read on UD pulley's......so you guys suggest march over ASP? what about march vs. slp (let's also compare best bang for back with that, i assume SLP's is much more) when putting on an UD pulley do you need a new belt also since it seems to me the stock belt would be loose? thanks.
Old Mar 24, 2006 | 12:35 PM
fire_boy06's Avatar
What problems could happen when putting a pully on a LS1?
What exactly is a pully?
Im dumb.
I was also looking into buying one but I would like to know what it is first.
Old Mar 24, 2006 | 12:57 PM
JDJP's Avatar
can someone go more into depth about putting the UD pully into an A4?
You need to buy an OD pully too?
Old Mar 24, 2006 | 06:31 PM
GR8GAME's Avatar
I am wondering the same thing. Anyone?
Old Mar 24, 2006 | 06:48 PM
WantedRawb's Avatar
i should be getting my slp ud pulley soon ill weigh it if anyones interested...i went with slp because of the thicker walls...had a previous experiance with another brand on another car where the belt would jump off every couple hundred miles...
Old Mar 24, 2006 | 07:54 PM
GR8GAME's Avatar
Has anyone had belts fall off w/ the ASP and or March UD pulleys? I would rather go w/ an ASP or March if they are lighter or better than SLP in any way...
Old Mar 24, 2006 | 08:42 PM
Dip Stick's Avatar
Ok call me the retard :0 Won;t be the first and I wear the name well What does dampening do or mean in regards to the above post..
"The ASP is probably the lightest compared to others, but is not known for it dampening ability."
Thanks. Be kind to the stupid
Old Mar 24, 2006 | 10:03 PM
daryl2cb@yahoo.com's Avatar
powerbound and SLP are the same, I would get the powerbond, I think they make the slp piece
Old Mar 24, 2006 | 11:41 PM
  #32
kartoon's Avatar
You can go to www.ls1howto.com.
pretty sure youll find some info there on the install.
Old Mar 25, 2006 | 01:04 AM
  #33
SLP LS1's Avatar
I didn't see anything on there about underdrive pulley install
Old Mar 25, 2006 | 01:12 AM
  #34
SLP LS1's Avatar
Originally Posted by prostock_bigblock
"Overdrive" pulley will solve the problem for A4`s. th OD pulley job is to bring back the alternator speed to its previous stock levels and this will solve the problems in Autos.
Seems as though everyone's guessing on the A4s...
Is there a gain on A4? dyno proof? not I can feel the difference...
Then there's this OD pulley question, do you really need an OD pulley?
"prostock_bigblock" sais you do, but there's a lot of guys on here that running the u.p. without the o.d.
Old Mar 25, 2006 | 02:32 AM
  #35
well in my previous 98z28 A4 I ran only UD pulley and no charging problems at all , but ppl with sound systems will find some charging lose and will need th OD pulley.
gains r between 7-13RWHP .
Old Mar 25, 2006 | 02:42 AM
  #36
Redneck Z's Avatar
Personally I don't think the SLIGHT weight difference between the steel SLP/powerbond pulley and the lighter aluminum pulley's will make a hp difference. I think the size of the pulley is where 99.99999% of the gains come from. As far as spark knock, the steel powerbond pulley won't distort over time like some of the aluminum pulley's have and cause KR. The SLP site says that the powerbond pulley won't cause KR, and it doesn't. I have the SLP pulley and data logging show's that I definately don't have any KR issues.
Old Mar 25, 2006 | 05:46 AM
  #37
Benjamin Russick's Avatar
I've had my ASP pulley installed for four years with no belt-jumping and no KR. I thought it was a worthwhile investment...
Old Mar 25, 2006 | 08:33 AM
  #38
mpe488's Avatar
how much does it cost for the new belts, and should I really be expecting anything close to a 2mpg gain? Cause that would be pretty awesome.
Old Mar 25, 2006 | 04:46 PM
  #39
you only need one belt, and i bought a gatorback today and those are the higher costing belts from autozone, and it was 32 bucks
Old Mar 25, 2006 | 04:51 PM
  #40
Bill Bowling's Avatar
Originally Posted by fire_boy06
What exactly is a pully?Im dumb.
Go here for install instructions.
http://www.bowlingss.com/Mods/Instal...e%20Pulley.mht
Bill
