Port-Matching FAST Intake to Heads
If you went with a .010" thinner HG, and a .010" mill on your heads, then each intake-port would be "shifted" .020" closer to the block. Thus, the roof and bottom of the heads' cathedral ports would be shifted in relation to the intake manifold's ports - and any mismatch at that time could then be marked and epoxied/dremeled to match.
Is my thinking correct?
https://ls1tech.com/forums/generation-iii-internal-engine/463971-port-matching-how-question.html
