Grotts with SLP Y-Pipe
Josh
<strong>Damian, I was under the impression that SLP didn't sell their header Y-pipe separately or are you talking about their stock replacement Y?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Fulton, actually I picked up an SLP y-pipe from a buddy, that came with his longtube headers. I am not sure if you can get the y-pipe seperate or not. Knowing SLP, probably not..
josh
I'd look for a local shop to build you a custom 3" Y-pipe for the Grotts once you get them installed. SLP uses Random Tech 3" 8100-series bullet convertors I believe. You can get these through SLP or another sponsor (cheaper) if you want. Grotts generally use a 2-bolt ball flange at the collector, so you'd need the mating parts for those, some 3" pipe and mandrel bends, the convertors, and a Flowmaster collector with reducer (unless you're running a 4" exhaust) (www.mufflex-performance.com might be a good source for some of this stuff).
Hope that helps.
<small>[ July 07, 2002, 12:08 PM: Message edited by: Fulton 1 ]</small>
