WS6 INTAKE CHOICES
Old Jul 14, 2002 | 03:27 PM
WS-6 BILL's Avatar
Default WS6 INTAKE CHOICES
I,M THINKING OF GETTING THE FTRA WITH STEALTH LID. ANYONE KNOW HOW MUCH HP I CAN EXPECT? ANY OPINIONS IS THIS LID WORTH $320. ANY OTHER SUGGESTIONS? AFTER THESE MODS SHOULD I STILL REMOVE BAFFLES? HOW DOES BG RAM AIR MOD COMPARE? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 14, 2002 | 05:32 PM
WILWAXU's Avatar
Default Re: WS6 INTAKE CHOICES
The WS6 lower air box is HARD to beat.. I suggest getting an aftermarket lid only.
The FTRA is a good idea.
Yes.. remove the baffles
Old Jul 14, 2002 | 08:14 PM
WS-6 BILL's Avatar
DOES THIS MEAN THE STEALTH SET UP CHANGES THE LOWER AIR BOX TOO?
Old Jul 15, 2002 | 11:15 AM
WILWAXU's Avatar
Yes, it is a lid & lower airbox combination.
Old Jul 16, 2002 | 02:03 AM
WS-6 BILL's Avatar
any way i can get directions how to remove baffles? Does this mod make car noticeably louder?
Any hp gain?
Old Jul 16, 2002 | 09:29 AM
NoGo's Avatar
I can't help you with directions on removing the baffles. There are a few floating around the net.
In my opinion, removing the baffles is going to do absolutely nothing for you.
Get an aftermarket lid if you wan't to up your HP. Messing with the intake path won't make your car noticeably louder. However, when you go to an aftermarket lid and remove the intake silencers (the two hollow chambers connected on either side of the intake) it will make a cool sucking sound when you get on the gas. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 16, 2002 | 10:09 AM
Bad02WS6's Avatar
I didn't have any instruction, but this is what I did.
The baffles are held in by aluminum studs that have been flatened on the inside. I use a 1/8th drill bit to drill the studs out.
The big baffle has studs in the rear. After you drill out the studs. Push the big baffel to one side and turn it flat. You should be able to pull it out no problem.
The twin front baffels have studs on the bottom. Drill out the studs. The Twin baffels are also glued in. From the front. I pushed the baffels back into the ram chamber. It takes some pressure, but they will pop off.
Hope this helps. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 16, 2002 | 08:37 PM
WILWAXU's Avatar
Replace "stud" with "rivets" in the above post <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
The back baffle is held in by rivets, easily drilled out. The 2 front baffles are glued in and will make a real ugly sound when you pull on them.. but it will be alright <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
