Exhaust Question, not the usuall catback BS
new plan is to install an X pipe right at the headers and then have the cutouts and back down to the y-pipe to the dual dual muffler I am using.
So basically when the cutouts are open I am running a very short dual exhaust setup with x-pipe, and when closed I am using a stock single intermediate type.
I am figuring that the x-pipe will make up for any TQ losses I might get while still allowing for nice top end and some tuned sound. And if it winds up being too little BP I can always close the plates a little.
<small>[ July 16, 2002, 09:57 AM: Message edited by: Cybertech ]</small>
Justin
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Steve
I hadn't considered the ground clearance point, I will have to check that out.
and headers. The pic shown is right at the brace,
where the right and left SLP header pipes join,
as you can see they hang down a bit. This would
be the location where clearance is an issue.
I belive some install the dumps downstream from
the Y but upstream from catback.
here is the pic.
http://ls1info.com/rearbrace.jpg
