Very serious NEED HELP
Old Jul 20, 2002 | 01:41 PM
roguevegals1's Avatar
Default Very serious NEED HELP
HELP. my car is running like ****. ok heres the story. i was low on gas so i pulled into a lowes marketplace gas station. after i filled up i went for a drive and all of a sudden the car starts to rev up real high than drop real low. when i am at a light the rpm's move very nasty. when i was looking around the engine looking around i saw the TB was full of carbon biuldup or oil. so i removed the throttle body and cleaned it out, replaced the TPS, and cleaned the AIC. Now when i hooked everything back up it is idling very rough and now on an average take off the car sounds like it is choking at part throttle. when i WOT the pig it acts right. What could be the problem.
Old Jul 20, 2002 | 01:46 PM
amazza76's Avatar
Default Re: Very serious NEED HELP
Sounds like a possible vacuum leak
Old Jul 20, 2002 | 01:53 PM
where would be a place to look. i checked the slp lid, bellow, SLP MAF, and the intake connection for leaks where else might there be a leak.
Old Jul 20, 2002 | 02:05 PM
2000LS1's Avatar
I know it sounds random but I had the same problem in another car (it was TBI though) and I got the fuel pump replaced (dealer technician's advice), and everything was fine. It's worth a shot to check I think.
Old Jul 20, 2002 | 02:24 PM
Old SStroker's Avatar
Perhaps you got gas with water in it. Dump a can or two of "dry gas" or it's equivalent in the fuel tank.
Change gas stations.
Old Jul 20, 2002 | 02:29 PM
i removed all the original gas that was in there and i replaced it with supreme and a bottle of STP entire fuel system cleaner and it is still doing it. <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
Old Jul 20, 2002 | 02:33 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
A friends mustang does that. If it's what I think your talking abou8t it's the same. His car surges from idle to like 2 grand and stays there. His car doesn't run roughly though. Someone told him it was his valves. Someone else said his injectors, and someone else said it was high 190lph fuel pump.
Old Jul 20, 2002 | 02:58 PM
BUMP
Old Jul 20, 2002 | 03:57 PM
I just tried the idle relearn and it is running like a misfire.please help. it is saturday night and i do not want to be stuck at home like last night.
Old Jul 20, 2002 | 05:27 PM
98blackSS's Avatar
Need to get a scanner hooked up and see what's going on. Is it acting up all through the rpm range? Cutting out more in the high revs? Throwing any codes? How's the plugs look? You mentioned excessive oil behind the TB plate. Pull off your PCV line going into the TB and check for oil bypass. Quite common on our cars and is not very O2 friendly over time. If you can't get a hold of ATAP, it's going to be a little bit of a guessing game. If you can, look at your IAC count, maf rate, O2 readings, etc.
Old Jul 22, 2002 | 03:08 AM
1dirtyZ's Avatar
if you have it , i'd check the egr tube's oring ( going into the manifold).just make sure when you tighten the bolt holding the tube to the manifold not to over tighten it , just snug it in , it stripps the thread pretty easy.
does the car run ok at mid to higher rpms???
Old Jul 23, 2002 | 09:17 PM
ran right at high rpms but now it is sounding kinda drowned out. at partial throttle it bogs nasty
Old Jul 23, 2002 | 10:06 PM
Sears's Avatar
!Dial-up Director
Change your fuel filter, check for loose grounds ( PCV ground on the passenger side, just follow the tube that connects to the throttle body).
Justin
Old Jul 25, 2002 | 07:38 PM
i had my car put on a scanner today and i got to write down some of the freeze frame info. what do you think about this.....
IAC= low was 118 and the highest point was 139
RPM= 830
ECT= -38 and did not change
IAT= 104
Spark advance= 22deg
egr position= 0%
ECT= went on a seperate datastream and got 115
Old Jul 25, 2002 | 07:40 PM
and...........
MAF= 8 g/s
TPS= closed was 0.59 and WOT was 4.3
Old Jul 25, 2002 | 08:30 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Bad TPS = car accelerates really slowly like you are pulling a house behind the car
Old Jul 25, 2002 | 08:49 PM
barely replaced the TPS. drives like that but at WOT takes off like a bad a$$ out of hell
