oil dipstick tube
Originally Posted by stillremains
I FINALLY got that son of a bitch out today. I appreciate all the help guys!
Good luck.
If the tube is jacked up, you can get a new one from the stealership for like $12 bux or something, just to make sure it goes back in nice. I think they had one in stock after i broke mine.
Like i said before, i dab a little grease on mine before i reinstall them.
I just ordered a new one from the dealer but have no idea when its going to arrive. Would it be alright to drive the car without one or should i wait?
Even though it is not pressurized, you will most likely have **** flying out all over your headers and it would make a huge mess.
Wait for the new one.
Or if the old one is not damaged at the base, maybe you could pinch closed the opening in the tube and reinstall it as a plug. Then install the new one at a later time.
Strange mine came right out. Getting it back in will make you think about pulling the starter. I should have since I didn't disconnect the battery I got some sparkys when I touched it with the dipstick tube. Scared the **** out of me!
Thats actually a good idea but there is no way mine will go back in. Lets just say I had a little fun with it after it took me longer to remove that then the rest of the exhaust. Thanks for the info and I'm going take your guys advice and wait for the new one.
Mine is like the f'n sword in the stone as well. I tried tieing a power chord to the base of it and pulling up on the chord with the assistance of a jack and all it did was rip the chord. ugh. For some reason I thought the chord would hold. I'm gonna try the visegrips.
Try getting it to spin in the hole a bit. Not sure if there's something special you need to do with LT1's, but you just have to call down the wrath of god on some of the LS1 tubes and PULLLLLLLLLLLLL.
