Macs on, Temp up..
Old Jul 21, 2002 | 05:56 PM
Zshark's Avatar
Default Macs on, Temp up..
Why would my car run 15 degrees hotter than average when i installed my mac headers w/orp? Does this mean that the a/f ratio became lean?
Old Jul 21, 2002 | 06:30 PM
NastySSoo's Avatar
Default Re: Macs on, Temp up..
I dont honestly know why it would. I never noticed it on mine. Are you looking at the factory gauge, or A Tap or scan master??
Old Jul 21, 2002 | 10:32 PM
Zshark's Avatar
Both atap and gauge says it is hot, i guess i just need to get the 160 thermo and fan switch, the temp isnt high enough to be harmful.
Old Jul 23, 2002 | 06:12 PM
Z06PSI's Avatar
Zshark. I am also in Evans GA Email me at abaker38@comcast.net and we can meet up.
Old Jul 23, 2002 | 08:58 PM
Damian's Avatar
LSX Mechanic
Are the Macs coated? If not, thats where your problem is. Macs give off more heat than stock manifolds, so your under hood temps will rise upon installing them. I have the 160 stat and programmed fans and I have no problems. However on a stock cooling system you will probably see a slight increase in temps...
Josh
Old Jul 24, 2002 | 01:52 AM
rnr27band1's Avatar
I also think your FTRA might be heating up the temps, along with the uncoated macs, i didnt even think of that the other day when we were talking about the temps.
