Inline pumps
Old Jul 24, 2002 | 10:32 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Inline pumps
Who exactly does an inline pump work? I know that they are placed into the fuel line after the in tank pump. If the inline pump pumps a higher volume and psi than the in tank pump, how can the in tank pump supply the intake pump with enough fuel for it to work?
Old Jul 25, 2002 | 03:09 PM
WILWAXU's Avatar
Default Re: Inline pumps
You have the right idea. Most inline (vortech, NOS, etc..) pumps are "pusher" pumps. They help mainatain a high psi at the rail...
Old Jul 25, 2002 | 04:11 PM
ls1290's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WILWAXU:
<strong>You have the right idea. Most inline (vortech, NOS, etc..) pumps are "pusher" pumps. They help mainatain a high psi at the rail...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So an intank pump would be better than an inline right? I am assuming that the intank will keep the pressure at the same rate all the way up the fuel line and to the rail rails and the inline pump will only keep the pressure from itself( where ever is it installed at ) up to the rail rails. For example:
Inline:
tank------50 psi-----inline pump------65 psi-------fuel rails
Intank:
tank------65 psi------fuel rails
Is this a right assumption? I guess that for the inline pump, it would have to have the same flow rate as the intank pump. If not, wouldn't either part of the fuel line ( either before or after the inline pump ) go dry?
Old Jul 25, 2002 | 09:32 PM
WILWAXU's Avatar
What are you running? Power adder?
Yes an intank would in most setups work better... not only that.. but you could always add a inline after the intank <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> if it's needed.
Old Jul 28, 2002 | 02:02 PM
menikmati's Avatar
in most cases an inline pump will pull the extra fuel it needs through the in tank pump.
