Car troubles again....HELP!
Old Jul 25, 2002 | 08:25 AM
BIGBOS's Avatar
Default Car troubles again....HELP!
I was going out yesterday to drive to gas city to fill up on some 100 before I sprayed the car....
Previous to this my car was sitting in my driveway idling for about 10-15 mins and nothing was wrong...
On the way to getting gas, I had the music up and I could tell something was wrong, the pedal felt dead, and smelled unburned gas..I pull over to a side street and get out and the motor is shaking something awful on the motor mounts....its got a pretty bad knock at idle, but it will hold an idle, for sometime it would not hold an idle, but now it does and knocks bad...I had it towed to speed inc, they hooked up the A-tap, it showed zero misfires....
And there was just a bunch of bogus codes the car was throwing.... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Any ideas guys help me out here.... <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
<small>[ July 29, 2002, 10:57 AM: Message edited by: BIGBOS ]</small>
Old Jul 25, 2002 | 08:45 AM
DriveATransAm's Avatar
Default Re: Car troubles again....HELP!
try reseting the PCM and see if that clears it up.
Old Jul 25, 2002 | 10:09 PM
BIGBOS's Avatar
TTT
Old Jul 25, 2002 | 10:32 PM
Sears's Avatar
!Dial-up Director
What were the bogus codes? If mostly related to elctrical components that it sounds like a bad/loose ground somewhere. Maybe your tach ground? Did you pull the plugs?
Justin
Old Jul 25, 2002 | 11:03 PM
BIGBOS's Avatar
I saw a lot of anti-theft codes, about 3-4 of those...
Crank position sensor...(but this warning has been on for a long time, and I've never had problems w/it)
Also the A-tap was picking up the codes for the wrong year...like 98...
Any more ideas?
Old Jul 26, 2002 | 07:59 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
BV tuned your car back when you needed a reflash to a different year to use Edit on an ’01 right? Maybe that’s why you’ve got ’98 codes?
Will the motor rev right? Maybe replace the CPS since you’re getting a code for it?
Old Jul 26, 2002 | 09:16 AM
BIGBOS's Avatar
I heard that the crank position sensor is quite pricey to replace... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 26, 2002 | 09:30 AM
dont you love cars after youve gone and fucked them up when they were running fine before <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 28, 2002 | 02:04 PM
BIGBOS's Avatar
I was out of town for 2 days, but heres an update...
All 8 plugs were toasted, they replaced them, made the motor run a little better, but still knocks...
Somewhere, somehow, the motor is flooding itself...
They are going to pull off the valvecovers soon to see if it might be a spring, if not in there, they will start doing a compression test..
Any more imput you guys could provide would be appreciated...
Thanks a lot,
Bos
Old Jul 28, 2002 | 06:41 PM
Operation BirdBOMB's Avatar
POS 941.
Old Jul 28, 2002 | 10:11 PM
BIGBOS's Avatar
Thats what I'm hoping for...
Anymore ideas guys...
TTT
Thanks.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 29, 2002 | 03:02 AM
Did you spray the car yet?
If 1 broke there is no reason all 8 plugs would be shot. How old were they? What did they actually look like? White, grey, black, oily, or physically damaged?
Next time you need your plugs changed, let me know. It'll be cheap and I'll teach you how to do it at the same time. Pulling off a valvecover is real easy too.
This is peanut if you didn't know.
Old Jul 29, 2002 | 10:53 AM
BIGBOS's Avatar
They told me that all of them were fried, but heres another interesting thing I forgot to add...even will all plugs gone, and the motor knocking as bad as it was, the A-tap was showing ZERO misfires..
The car has NOT been sprayed yet....
Old Jul 29, 2002 | 11:35 AM
BIGBOS's Avatar
Well I just got a call...
They did a compression test on the driver side and it was fine, and before they did it on the passanger side (the hard side) they pulled the fuel line going from the solenoid off the fuel rail, and now it runs fine...
So were thinking something isn't wired right, or I have a shitty TNT fuel solenoid...but if the wiring was wrong it would cause the solenoid to spray the fuel only above 3000...
Confused... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
They changed the plugs again, and it runs a little rough at idle, he said there is a slightly bad plug or 2 or 3...but he said it should clear up as soon as it goes WOT...is this true??
Thanks,
Bos
Old Jul 29, 2002 | 05:23 PM
BIGBOS's Avatar
Well I ended up gimping it home today....
Same deal still, runs like crap...I assume all the plugs are fried again...
I hear a distinct tapping comming from the passanger side valvecover, the driver side valvetrain is whisper quiet...
But the verdict is, my wiring was wrong somewhere, because when I went there I had a dead battery, which means that one lead was draining 12v's all the time, instead of being a switched 12v source, so I guess I will have to go through that when the time comes...
So I guess what happened was that when I was driving I was spraying a 75 shot of fuel on and off maybe about 2-3 times....everything falls together now, because now I remember smelling fuel right as the car started to run crappy...
But they have changed the plugs and that didn't make any difference....
Any more ideas on why my car is running like junk??
My fuel pressure is 59-60 range so thats fine, Coolant temps are at a steady 194....the OIL psi reads a little over and a little under 40psi, but that seems normal...
I need HELP!!!
<img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Jul 29, 2002 | 05:28 PM
minty's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DriveATransAm:
<strong>dont you love cars after youve gone and fucked them up when they were running fine before <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Id rather be fast and break than be slow and be you....
Old Jul 29, 2002 | 05:37 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Let's keep this on subject.
If you were spraying fuel it would mess up the plugs.
Don't know what to tell you, if it's tapping, you need to investigate or drop it off to be fixed.
Old Jul 29, 2002 | 07:39 PM
minty's Avatar
I tried to keep it on the subject, It was about why bos' car breaks and roy's doenst. Anyways, when you go internal bos, whether anyone wants to admit it or not. Its really luck of the draw. Sometimes a car has NO problems ever and sometimes the car is always breaking... Nothing you can do really except fix whatever problem you have.
Old Jul 30, 2002 | 11:30 AM
BIGBOS's Avatar
TTT
Old Jul 30, 2002 | 11:40 AM
LS1Tech Co-Founder
If your wet kit is wired wrong, or not working properly, you can end up spraying fuel ONLY.
So everytime you get into it you might have been getting a shot of fuel. Will bog the motor down and get the plugs wet.
Is it still tapping?
