Throttle cable adjustment w/ Traction control.
Old Jul 25, 2002 | 04:26 PM
Country Boy's Avatar
Senior Member
Default Throttle cable adjustment w/ Traction control.
How do you adjust this stupid thing. Heres the deal.....
I know how to adjust it, butI have a MMS throttle body with the bump stop ground down, but the throttle wont open all the way up to the stop, but if I adjust it to where it does open all the way, it idles at 1500 RPM. It wont go all the way down. So its either open all the way and idle at 1500 or idle where its supposed to and not open all the way.
Am I missing something?
Old Jul 26, 2002 | 09:38 PM
Old SStroker's Avatar
Default Re: Throttle cable adjustment w/ Traction control.
One possibility:
The shape of the 'cam' on the throttle shaft where the cable attaches changed in 2000 and up, I believe. It's physically longer and a different shape from the 98-99 cam. I'm not sure, but I suspect if you installed a pre-2000 TB on a 2001, the cable and linkage might not work together. If you still have your original TB, compare the cam shape. If they are different, contact your TB supplier.
I've seen a lot of modified TB's recently, and cores for 2000 and up are very scarce.
Old Jul 27, 2002 | 04:23 PM
SStrokerAce's Avatar
I'm with old stroker on that one. Check the throttle cam.
Old Jul 27, 2002 | 04:34 PM
Poltergeist's Avatar
A friend of mine had the same problem, owns a 00 and got a 98 TB, and had to get a throttle cable for a 98. Fixed his problem.
Old Jul 27, 2002 | 04:36 PM
Senior Member
I hope MMS didnt send me a wrong TB, Ive had it for about 9 months now. I dont think I could return it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Im checkin it in a few with the GFs 2002 SS.
Old Jul 28, 2002 | 01:36 PM
Senior Member
I seen the difference with the cams. Its a BIG difference. I do have the right TB. So... I dunno <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
