BANGING BANGING BANGING!!!
Old Jul 27, 2002 | 06:44 PM
jeff's Avatar
Default BANGING BANGING BANGING!!!
i am sick of this. everytime i do a burnout or i rip it in second gear something is banging. i can see marks on my headers on the driverside. i know it is not my ypipe. my whole center console like moves when i do a burn out or i slam it into second gear. so i went to speed inc. they said it was my torque arm that was cracked then i replaced that. and then it still banged. then i got torque straps it helped a little but it still bangs. i do not know what it is. could it be my trans mount??? because it seems like it is my trans hitting and moving my center console. should i replace my trans mount with a poly urethane one? i am so confused any one else have this problem. it just wont stop. and when it bangs it is causing knock retard and i am losing hp! any ideas or thoughts thanks!
jon
1998 ws6 M6
Old Jul 27, 2002 | 07:22 PM
H82BBad's Avatar
Default Re: BANGING BANGING BANGING!!!
sounds like a trans mount
Old Jul 27, 2002 | 07:55 PM
Zshark's Avatar
Are you sure that it is not wheel hop. My wheels dont hop in a forward burnout, but a burn out in reverse wants to shake the car to peices, and the way that you described it it sounds like my experience with wheel hop.
Old Jul 27, 2002 | 08:15 PM
ONYXSS's Avatar
If you've replaced your tranny mounts, then I'd look at your motor mounts. I drove for a while with a broken one, and you don't notice it until the WOT runs.
It's not that big of a deal. Good luck.
Old Jul 28, 2002 | 01:03 PM
mccdubbbs's Avatar
if it is my trans mount what kind should i go with? i have heard poly urethane ones shake the car a little or rattle. and if it is my motor mounts what kid do i go with. i have heard solid motor mounts cause the car to shake alot. thanks
1998 ws6 M6
Old Jul 28, 2002 | 01:16 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
If it's the mount replace it with a 1LE mount. They are stronger than the regular replacement. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 29, 2002 | 01:02 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you are M6, and the tranny makes noise on 1-2 shift, and the shifter visibly lifts up, then the tranny mount might be tearing apart.
Old Jul 29, 2002 | 02:05 PM
Xsta Z 28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mccdubbbs:
<strong>if it is my trans mount what kind should i go with? i have heard poly urethane ones shake the car a little or rattle. and if it is my motor mounts what kid do i go with. i have heard solid motor mounts cause the car to shake alot. thanks
1998 ws6 M6</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Energy Suspensions Polyuerethane mount! The 1LE will still tear.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Zshark:
<strong>. . . a burn out in reverse wants to shake the car to peices. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">God ain't that the truth!!!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jul 30, 2002 | 12:45 AM
mccdubbbs's Avatar
ttt
Old Jul 31, 2002 | 04:07 PM
jeff's Avatar
I FIXED IT!!!! FINALLY. GOOOOOD. IT WAS A TRANS MOUNT! I BOUGHT A POLY URETHANE ONE. I WAS SO HAPPY WHEN I DID A BURNOUT AND IT DID NOT BANG!!! AND WHEN I HIT IT HARD INTO SECOND IT DIDNT BANG! I AM SO HAPPY AND IT WAS REALLY EASY TO INSTALL ME AND MY BUDDY DID IT! IT HAS BEEN LIKE THIS FOR SO LONG!!! I AM SO HAPPY. HOW MUCH COULD I LOSE BY THIS HITTING. BY HORSEPOWER WISE. I WANT TO KNOW IF IT CAUSES KNOCK RETARD. IT FEELS LIKE IT PULLS MORE AT HIGH RPMS. AFTER THE SHIFT. THANKS.
JON
1998 TRANS AM WS6
Old Jul 31, 2002 | 11:35 PM
ls1snakebiter's Avatar
i hate to tell u this, lOng tubes suck on these cars. I have longtubes on mine and they bang everything. So im taking them offf mine not really worth the money and suffering.
