How much does LS1's oil problem(PCV valve) change timing or ping and KR?
I am wondering how much timing the computer could be pulling out due to excess oil in the combustion chamber? I recently pulled my intake off and found the runners were covered with oil. Is there any intake/combustion chamber cleaner you can use while the car is running? Something say you can spray into the intake track and it will burn the oil/solvent? Thanks!
Phillip <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Re: How much does LS1's oil problem(PCV valve) change timing or ping and KR?
gm top end cleaner should clean up your intake and combustion chamber. get two cans of the spray cleaner. spray into the tb and let the car sit for at least an hour or more and then go do some hard wot driving to clean it out. DONT get it on the maf or youll ruin it. i just read up on the top end cleaner because im going to be using it in a week or two.
<small>[ August 07, 2002, 09:28 PM: Message edited by: hondakiller ]</small>
