Tired of TTS system... looking to Grots + ORY
I have a set of ARE S1 heads and a TR224 cam. With this combo and the exhaust system above, I made 406 RWHP/386 ft-#. Not bad for restrictive TTS cats, eh? Well I want more. Low and mid-RPM response are incredible, but it feels as if it's choking at the upper revs. I'm now looking to replace the cam with something bigger and need to have this exhaust bottleneck resolved.
The TTS headers have let me down... they make a ton of noise (fluttering noticable in the cabin)and don't provide the best ground clearance. With the cats, they're near equal to SLP LT in ground clearance. My replacement headers will be 1 3/4" Grots. As for a Y-pipe, I'm at a loss... I want to enjoy T-top free driving, and if things get too smelly, I'll have to pick up a set of Random 8000-series cats.
Given my situation, do I stand much to gain by getting rid of the TTS headers? Should I integrate cats into my future Y-pipe or leave them out for the time being?
<strong>Umm that flutter is a 10 cent fix... that you will have to do to whatever headers you buy.. http://riptide63.homestead.com/restrictor.html</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've already performed that "fix" while replacing both check valves. That was a complete waste of my time and money!
I am pretty sure my tts will sound good with my b and b as the car isn't very loud at all now and with cats can't see it being that bad.Also for ground clearance I have seen these headers on
some lowered cars without any apparent problems.My car only has the slp eibachs so hope I am ok that way .As for the fluttering noise a few guys on the boards not sure if it was this one or ls1.com said they noticed no strange noises with the tts..some header noise is usually common with any headers..the thinner wall the headers the more the noise usually..my factory 99 have some noise I think compared to the 2000 and up cast iron ones.I have a loud stereo and have dynamatted most of car so probably won't be too noticeable in my car..hope not.Also I thought the tts had a 3 inch ypipe?? Oh well..too bad I might have bought yours off you if hadn't ordered mine already..sure someone will take them..I better like mine..they weren't cheap..course what is on our ls1's..rear ends..heads..ouch..bend me over again!!!!
<strong>Umm that flutter is a 10 cent fix... that you will have to do to whatever headers you buy.. http://riptide63.homestead.com/restrictor.html</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have Grot headers/cats and 222/222/544/544/114 cam and have a fluttering, more like a chirping sound. I thought it was the check valves and so did the restrictor mod. That got me the service engine light and so I removed the restrictors. No more light, but the sound continues.
-Get a set of 1 3/4" Grots
-Build a 3" off-road Y-pipe into a 3 > 3.5 Flowmaster scavenger colletor
-Weld an 18" Dynomax bullet muffler in place of the existing Loudmouth resonator
<strong>Wow..I do research on the board for months and months trying to decide which long tubes to finally buy and decide on the tts a few weeks ago and now this post comes out and shakes me up..arghhhhhh ...!!!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Look bro, if you want a totally quiet stock-like car then keep it stock. Otherwise you are going to have small differences, noises etc. to deal with in certain areas when you begin modifying.
I have TTS headers and have run them for a couple years. They are great. My car also has ported heads and an aftermarket cam. Don't let anyone make you doubt your decision. TTS's are very good.
I dont really want to have to run a bullet.
You'll be fine with the OR pipe and the B&B...when you doing your heads and cam? That's the fun stuff...
Why? They are really good quality. Thicker gauge steel than the Grot's.
I currently run TTS longtubes and I used to have a set of Grot's.
Grot Y pipe is still not very good.
IMO do a little research on the gauge of steel used for the headers.
Grot's didn't use to have flanges, do they now? Mine did not and my cat's-to-header connections always leaked like crazy so I had them welded twice.
I would get a custom ORP or have bypass tubes made.
Your fluttering is:
-air valve (as discussed)
-exhuast leak
-leaky AIR pump, did you check to make sure they are tight?
-crack in header or pinhole leak
9/10 times it's an exhaust leak.
Even though I think that the guy who runs TTS is a difficult person, I have to say his headers are top notch.
I have a used set, his 2nd set made... They are still flawless, and they date back to mid 1998.
IMO this is a way where you redo a mod and just waste money.
Good news to hear about the funny noises likely being one of those things pro stock stated.I have taken off my air pump crap and have block offs for the egr and air tubes.I am curious to maybe try a custom offroad pipe on my tts at some point.I actually find the car pretty growly now even with just my b and b now that its got some miles on it.I just ordered the qtech controller and 3 inch cutout.That should take care of the occasional urge to have it louder.I have heard the grots are pretty good and have good ground clearance..problem is every time a guy buys the wrong thing it costs money.I have spent quite a bit in last few years trading up cars..had 96/97 and now 99tas.and have gone thru lots of different mods..
TTS longtubes are thicker steel than Grots... Now the Grots might be an average gauge of steel for LS1 headers, I don't know.
The TTS headers do not bang the floorboards at all.
I think that longtubes, ORP, and B&B can sound pretty good, but that's because the B&B has a tuned sound to it.
TTS' first set of longtubes are on the Goldrush TA showcar. I have the second pair... Our early sets have GM 2 ball flanges instead of the 3 bolt flanges of the ones since then.
My headers are holding up great.
I prefer a 3" ORP and that is what I used until I went dual exhaust.
