Finally an easy PCV solution for our cars
Old Aug 21, 2002 | 01:47 AM
Dope's Avatar
Default Re: Finally an easy PCV solution for our cars
Seeing as the product (and other products like it) do not add any restriction (minimal, I should say, the extra tubing and so forth probably counts for SOMETHING), I wouldn't think you'd have a problem. It's when you start introducing filtration devices in the lines that you will run into restriction problems (I gained 4-5psi of oil pressure going from a dual inline fuel filter setup to the catch can (Greddy that is, but same difference)).
Dope
