Any tricks for valve cover removale and replacement?
As far as I know the gaskets are reusable.. and tips for getting them back on without leaks? Also, anyone know the torque spec for tightening down the covers? any pattern?
Thanks in advance <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I dont see how you could mess it up to tell you the truth <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong>35 ft/lbs I believe.
I dont see how you could mess it up to tell you the truth <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Trust me.. i COULD find a way <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Just looking for things like "be carefull not to break the oil tube off when changing the intake manifold" sort of hints..
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ August 13, 2002, 02:38 PM: Message edited by: SPANKY LS1 ]</small>
The next step is to remove the coil packs. First pull the park plug wires off the coil packs (you can
leave them hanging on the plugs for now) Each coil pack is held on by five 10mm bolts. These bolts
have threads on the top of them, and are staggered across the coil pack brace. There is also one
connection per side that needs to be disconnected. It is the large connector in the middle of each
brace. Pull the blue locking tab out, and unhook the connector. The entire coil pack assembly should now come free and slide out. Be careful on the driver's side as you will have to negotiate around the fuel lines.
The passenger side is easier to remove once you get the bolts free. The hardest one is the furthest back on that side. You can't see it, and will have to feel around for it. Use the closed side of a 10mm crescent wrench to keep your tool on it. I came at it from the top, reaching over the intake manifold and then around the back of the fuel rail. It only allowed for about 1/8th of a turn of my wrench. This took a while, but eventually you can start turning it with your fingers.
Now that you have the coil packs off, you can see the four bolts that hold the valve covers on. These are 8mm bolts and should back out quite easily. They will stay connected to the valve covers, so don't worry about trying to remove them.
Re-Install
( u can use stock gaskets if they are rubber and
in good shape ).
Replace valve covers. Be sure to connect the two hoses on the passenger side, and the single hose on the back of the driver side cover. Tighten the four 8mm bolts on each side to 106 lb-in (8.83 lb-ft).
Replace the coil packs. Five 10mm bolts on each side. Connect the electrical connector on each side.
Replace the spark plug wires.
Reconnect the A.I.R. pipes to the hose (the hose sits into two clamps around the back of the engine)
and bolt the pipes back into the headers. Remember to use new gaskets here, as well.
That should do it..
re-install anything else you took off, intake ect.
Looks like I have a project to do today.. lol
Hmmm.. while im there I should replace my pushrods.. lol
Does it ever end? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks Again
--Remove EGR system
--Relocate coil packs under the cowl
--Cut and install new plug wires
--Shave the valve covers and polish or paint.
Change plugs in less than 20 minutes with no cuts/scratches. It was worth the trouble. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ryan
<strong>do you have any pics of this brotherJ? I've been wanting to shave and polish up my valve covers for a long time, but i never knew if it was possible. How do you relocate the coils? can you just move them? thanks
Ryan</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sent you 2 pics. Here's a link for relocating the coils:
http://www.geocities.com/mulot30th/C...Relocation.htm
