TB compatibility question
Old Aug 20, 2002 | 06:43 PM
jimmyblue's Avatar
Moderator
Default TB compatibility question
Is the TB the same for all LS-1 cars?
Are there year-to-year differences
between F-body LS-1 TBs? What about
Corvette TBs (will they fit & be
compatible, as far as fittings &
sensors)?
Old Aug 20, 2002 | 08:12 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: TB compatibility question
'98-'99 are the same, as are '00-'02.
The vette TBs will not work on a F-body. The throttle is controlled via the computer, so there is no throttle linkage.
Jason
Old Aug 22, 2002 | 06:37 PM
Old SStroker's Avatar
The "cam" on the end of the throttle blade shaft, which the throttle cable is wrapped over, changed in 2000. Early ones (and LS1 truck ones) are smaller. The shape of the cam determines how the TB blade angle is related to pedal angle. I don't believe you should interchange pre 2000 an 2000+ cams. You could have cable length problems too.
Vette is completely different as Jason said, except inside the bore it's similar, and ported similarly.
