For the Fast 90mm setup, whats needed exactly? bigger lid?
Old 04-12-2006, 06:58 AM
92SilverSHO's Avatar
Default For the Fast 90mm setup, whats needed exactly? bigger lid?
Obviously i know the fast 90 intake, NW90 TB, But what about an 85mm lid and 85mm Maf? Can i keep my stock maf, or will it be a restriction? Anyone still use the stock maf and normal lid with a fast 90setup?
Mike
Old 04-12-2006, 07:00 AM
Detroitmuscle's Avatar
I have the SLP lid and the stock MAF on my 90/90 setup and it works just fine. I'll probably eventually step up to an 85mm MAF and lid, just didn't wanna have any issues with tuning it.
Old 04-12-2006, 08:46 AM
SSilverSSurfer's Avatar
i have an slp lid and Z06 maf....but i had to go to home depot to get plumbers rubber tubing(3in to 4in) to go in place of my bellow
Old 04-12-2006, 11:56 AM
Thanks guys! i just wanted to keep my stock Maf for the reason above, with tuning.
Old 04-12-2006, 04:26 PM
SSU's Drunk Typing Whore
Lithium's Avatar
yeah its fine, I am probley going to keep the lid and stock maf then step it up when tsp gets some 85mm lids in.
Old 04-13-2006, 10:24 AM
lsx24's Avatar
Sure, there is a transition from a 85mm maf to whatever lid you are running--at the moment--I am lucky because my suncoast setup's opening is larger than 75 mm (as you can see in the pic), besides the fact a wide v-pattern vacuum area is placed right after the neck. Therefore [as you can see in the pic] the combination not only does not create a restriction, but it feeds the intake assembly plenty of air.
Old 04-14-2006, 06:54 AM
lsx24's Avatar
Um, more clearly, the adapter you see there was not purchased separately, I am saying it's great because it came with the MAF adapter.
